2010 2011 BMW 5 Series Forum F10 Base Brakes: Anti Rattle Clip Install Tips??? |
01-26-2019, 11:21 PM | #3 |
Rep 508
I discovered that having the piston fully compressed will give you some flexibility and space.
One option is to hook top, insert center tab, and then force bottom hook with a flathead screwdriver. Second option is to install both hooks, and force the center tab by prying up, and pushing tab into place. So, this is what I did... Rotors - StopTech Dust Shield - VHT Primer, VHT Satin Black Caliper/Mount - VHT Primer, VHT Titanium Silver Blue, VHT Clear Rotor Set Screw - ECS Stainless Pads - OEM BMW Sensor OEM BMW Rattle Clip - OEM BMW Lotsa prep work. Took hours to clean. Used Dremel, wire brush, brake clean, etc... Happy with results; however, will go back in a week to touch up a few spots. In the near future, I'll take better pictures to post. Special thanks to Member Tallest for inspiring me to do this. His post can be found at: https://f10.5post.com/forums/showthread.php?t=1466735 Last edited by John H.; 01-28-2019 at 12:22 PM.. Reason: Added info. |
01-28-2019, 12:20 PM | #8 |
Rep 508
02-03-2019, 11:29 PM | #9 | |
Rep 20
John H.310.00 |
02-04-2019, 12:11 PM | #10 | |
Rep 508
02-04-2019, 01:30 PM | #12 |
Rep 5,605
Be alert for micro-cracks from the holes. I had a few sets (I don't really remember the brands) and they all developed micro-cracks emanating from the bevels at the holes.
02-04-2019, 01:39 PM | #13 | |
Rep 508
My first set of StopTechs. Hopefully, they will hold up. |
02-27-2019, 10:00 PM | #15 |
Rep 2
Drives: 2014 BMW 535d
I just did a full brake job and caliper paint. That front clip is a huge PITA.
I had to take a break the first night. https://f10.5post.com/forums/images/smilies/mad0260.gif What worked was pushing the caliper tight against the outside of the rotor, then sliding the end tabs of the clip behind the caliper bracket while keeping the plate tight against the caliper. Then insert a screwdriver in the hole in the bracket while pushing in on the handle towards the rotor while pushing the hole end out towards where the rim of the wheel would be till the half moon tab slid in the groove. |
02-28-2019, 01:21 AM | #16 | |
Rep 508
AussieBob81.00 |
06-26-2019, 08:52 AM | #18 |
Rep 1
Link to Anti-rattle clip
Hi, new to this forum. Going off of this thread, can anybody send a link to the anti-rattle clip online? Mine has fallen off when doing the front brakes and I need to get a replacement.
06-26-2019, 02:00 PM | #19 |
Rep 38
Realoem.com is going to be your best friend..you can do shopping on fcpeuro or ectunning. Part number might be 34116799386 and part only cost 20 bucks in fcpeuro..again cross reference your vehicle in realoem.
06-26-2019, 07:25 PM | #20 |
Rep 508
Have been monitoring the rotors. Nothing unusual to report. Has held up very well. StopTech/Centric rotors are solid.
05-30-2022, 05:48 AM | #21 |
Rep 92
Good bloody Lord these clips are really difficult, the worst BMW model I have ever had to deal with for brake pad changes. It has to be the worst anti-rattle clip design. I can see why aftermarket calipers are an option.
I used your first described method john H. and got the clip in three times before I was happy with how it lined up and gave it a road test. I used needle nose pliers, simliar to you, to bend and force the bottom clip in. If I see a huge long set in the future I think I will invest in it. It is a great joy that the rear calipers don't have these awful awful clips. New paint and decals are going on the calipers once I clear my head again. Why does BMW use this horrible design? What are the benefits, if any? Last edited by AussieBob; 05-30-2022 at 06:10 AM.. |
