01-29-2019, 09:14 AM | #1 |
5370
Rep 3,789
Eventuri Intake BMW F90 M5
Featured on BIMMERPOST.com The F90 M5 Eventuri intake system was developed through extensive real world testing and airflow simulation analysis. It demonstrates the perfect balance between allowing for unrestricted airflow with our semi-open filter housings whilst maintaining low IATs through cold air saturation with our scoop and shield combination. The large front air scoops transfer ambient air directly into the intake area thus ensuring the engine doesnt suffer from heat soak. In addition, the gold heat-reflective lined shields have integrated flow guides which direct the ambient air from the scoops into the filters. They have also managed to increase the inlet tube cross-sectional area by over 30% compared to the stock intake as it feeds through the openings in the strut braces. This allows the turbos to work more with less restriction and reduce the waste-gate duty cycles. The Eventuri Difference The F90 M5 Eventuri system uses their Patented Carbon Fibre Housings and Gen 2 bespoke filters, which provide an aerodynamically efficient airflow path from the filter to the turbos. Not just another cone filter with a heat shield but a unique design which invokes the Venturi affect and maintains laminar flow conditions to reduce the drag on the turbo. You can read more about the housing design and how it works here. Product details The Eventuri F90 M5 intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. Here are the details for each component and the design ethos behind them: Each intake system consists of: 2 x Carbon Fiber Venturi Housings with Integrated Tubes 2 x Bespoke High Flow Generation 2 Filters 2 x Aluminium Inlet Cowls 2 x Carbon Fiber Air Scoops 2 x Laser Cut Heat Shields lined with Gold Heat Reflective Material 2 x Laser Cut Air Ramps integrated into the Heat Shields High Quality Silicon Couplers and OEM Spec Hose Clamps INTAKE HOUSING ASSEMBLY The filter housings comprise of the bespoke generation 2 filters, aluminium inlet cowls, the carbon pods and integrated tubes. The carbon pods shroud the reverse mounted filters and smoothly shape the airflow down to the stock turbo inlet tubes. This is a key feature of the intake design where we have removed the requirement for a convoluted rubber hose between the airbox and the turbo inlet tubes. The filter housings and integrated tubes extend all the way to the stock turbo tubes and are able to move as one piece with the engine through the strut braces. This removes the extra interfaces of having a separate convoluted tube which the stock system requires for flexibility as the stock airboxes are mounted to the chassis so cannot move. The result is a smoother path from the filter to the turbo inlets and therefore the turbos are able to function with less drag. The diagram below summarises the differences between the stock airbox and the Eventuri F90 filter housing. INTERNAL VOLUME Another key design feature of the intake housings is the internal volumes of the tubing as they pass through the strut braces. On the F90 M5, the airbox system must pass through an oval opening in the strut brace on each side before reaching the turbo inlets. They have managed to increase the internal size of our intakes at this junction which results in more available volume for the turbos to draw from and therefore less restriction. The increase in cross sectional areas between the Eventuri and the stock airbox is 31% as follows: Internal Cross Sectional Area of intake tube at the strut brace: Stock Airbox Tube = 6487mm² Eventuri Intake Tube = 8497mm² PATENTED TECHNOLOGY The patented filter housings have a smooth reduction in cross sectional area as they shroud the filters and taper down to the tubing. This geometry invokes the Venturi effect where the airflow accelerates whilst maintaining laminar conditions. It can be thought of as a large velocity stack - below is a diagram to show the comparison between our patented design and a regular intake system. The bespoke filters aid the airflow moving through the housings and allow for an even velocity profile as the airflow exits the housings. HEAT SHIELDS AND AIR RAMPS The filter housings sit on top of these laser cut shields which also have a gold reflective backing to aid against radiated heat transfer. The shields attach to the chassis and also provide an enclosure for the openings of the housings to draw cool air from. This is aided by the integrated air ramps fixed to the inside of each shield. These ramps guide the air from the scoops upwards to the filters so when the car is in motion - the airflow being forced into the ducts from the front scoops is then directly pushed into the filter area displacing any engine bay heat. FRONT SCOOPS The final carbon components in this system are the front scoops - essential to direct ambient air to the filters. The scoops were designed for maximum efficiency in directing the incoming air to the stock duct openings. Many aftermarket scoops have a large flat area almost perpendicular to the oncoming air - not great for channeling it into the ducts as the airflow just "hits" this flat portion and creates turbulence. Unlike most aftermarket "scoops" the Eventuri Scoops have been designed extend from the stock duct openings all the way to the grills. In order to capture as much air as possible, the scoops are shaped to the same contours as the outsides of the grills and then smoothly channel ambient air through a continuous curve to the duct openings. CAD images to illustrate the shape: Having an effective cold air feed to the filters is an essential part of our design. Simply having some heat shields in place is not an effective means of avoiding heated air from entering the filters unless the shields create an air tight envelope around the filters. The scoops and shields in our system combine to provide the filter openings with ambient air and maintain low intake air temperature. Sound Clip Eventuri BMW F90 M5 Sound Performance The intake was tested on the road using a Vbox unit to record the acceleration from 60-130mph . Testing was carried out on the same stretch of road - again on the same day to keep variables minimum. Results show that with just the intake added - on stock software, the acceleration times from 60-130mph reduced by 0.22 seconds which is a significant improvement at such speeds. The car was tested three times in each configuration and the best time taken for each configuration for the results below. Acceleration results summary: 60-130mph with Stock intake = 8.48 seconds 60-130mph with Eventuri intake = 8.26 seconds The gains are from a combination of reasons: 1) The larger inlet tube volume alows the turbos to work with less drag. 2) The Venturi housings provide a smooth transition from the filter to the intake tube keeping airflow laminar. 3) The large front scoops force ambient air into the intakes keeping the IATs low. Installation guide: Eventuri Install Guide F90 M5 More pictures! |
01-29-2019, 10:00 AM | #2 |
///M
6652
Rep 3,683
Nice write up!!!
Didn't think it could save .22 sec Did you Dyno before and after to see gains in HP? It sounds sick, I love mine
Life is too short...enjoy your life
///M |
01-29-2019, 10:34 AM | #3 | |
5370
Rep 3,789
Glad you are happy with it. It does look and sound awesome too. |
01-29-2019, 10:53 AM | #4 |
Rep 275
Really like the looks! Hope to have one installed soon!!!
Imran@Evolve5369.50 |
01-29-2019, 11:14 AM | #7 |
BMW obsessed
9580
Rep 10,875
01-29-2019, 11:24 AM | #8 | |
5370
Rep 3,789
We would only ever test back to back so conditions are as close as possible. |
onfireX53617.50 |
01-29-2019, 11:57 AM | #9 | ||
///M
6652
Rep 3,683
I would also do multiple runs on each and get average to eliminate any error
///M |
M 4EVER191.00 |
01-29-2019, 12:00 PM | #10 |
5370
Rep 3,789
01-29-2019, 02:00 PM | #13 | |
Rep 2,602
Drives: MW Vespa w/pink racing stripes
Mustang Dyno AWD |
xander_g989.50 |
01-29-2019, 03:23 PM | #14 |
Rep 4,532
01-29-2019, 05:09 PM | #15 | |
Rep 275
01-29-2019, 06:03 PM | #16 |
Joint Chiefs of Staff
24161
Rep 190,725
Very nice
01-29-2019, 06:04 PM | #17 |
Rep 2,602
Yeah I'm not gonna lie, was expecting far worse, lol... There's a reason people call the mustang the "heartbreak machine" lol
Quickburn7955.00 |
01-29-2019, 09:08 PM | #18 | |
Rep 18,712
Everything slip in like a glove. Stupid easy installation.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
01-30-2019, 07:07 AM | #20 |
Rep 4,532
At 10” of H20 , the stock airbox assembly flows 445cfm with stock filters but charcoal deleted. With BMC filters it flows 492cfm. What does the Eventuri flow at 10” ?
03-07-2019, 10:23 AM | #21 |
Rep 1,124
Drives: G30 M550i
Looks very well made and the data looks promising as well.
03-07-2019, 12:34 PM | #22 |
Rep 3,297
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
