2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 Starter Replacement now crank but no start
      02-21-2019, 09:56 AM   #1
Topher Tuff
Drives: 2011 535i
Bimmer Team, I replaced the factory starter with a non OEM starter, the car will crank has 12.6v but does not start. The car is 2011 F10 with 90k and the message I get is drive train faulty. I have rechecked the connections and work performed yesterday. Austin, TX BMW says service is available 3/4... any help on common mistakes when changing a starter? Also when checking the hidden menu no error codes are present. the car craks but does not start. I was thinking surely there would be an error code.
      02-23-2019, 03:29 AM   #2
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Why did you replace the starter? Let’s start there.
      02-23-2019, 07:58 AM   #3
wcr3d
Drives: 2013 535i XDrive M Sport
The hidden menu won't tell you about error codes.
Get the codes read the right way and to from there.
      10-02-2019, 02:03 PM   #4
Topher Tuff
Drives: 2011 535i
sorry for very latent response ended up taking battery connections off and re-seating all connections to the ECU around the manifold and that was the ticket to success.
      10-02-2019, 02:04 PM   #5
Topher Tuff
Drives: 2011 535i
sorry for very latent response ended up taking battery connections off and re-seating all connections to the ECU around the manifold and that was the ticket to success. this happened the next morning when I could see fully. thank you for the reply
