2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Custom Intake Behind The Grill
      03-25-2019, 06:48 PM   #1
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
Trying to see who would be intrested in a bmw 535i Custom Fabricated Intake. If i get enough people interested on here and the 535i owners since we share the same intake i can get a batch made. Would be $575 shipped.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      03-25-2019, 09:13 PM   #2
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
That is some serious setup you've got going overthere. Have you had the car on a dyno to see if it made any power?
      03-25-2019, 09:19 PM   #3
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Stainless to aluminum? You need to figure out a way to not have so many welds on there. Looks almost like 180 bend, maybe do 2 90s and shave off some degrees as required....just a suggestion.
Edit: after a second look, it all looks aluminum am I wrong?
      03-25-2019, 09:31 PM   #4
$howtime456
301
Drives: BMW 640i
thanks my brother... this removes the need for stock intake so the bends are nedded to get inside the small opening in the passenger frame.
N55 GENERAL
David Shoup Tuned
      03-25-2019, 09:32 PM   #5
$howtime456
301
Drives: BMW 640i
made 500+ on 19psi before this setup, EOS fuel pump module, replacing a o ring on the charge pipe and leaky fuel injector. Hoping to hit the rollers soon and increase the output
N55 GENERAL
David Shoup Tuned
      03-25-2019, 11:05 PM   #6
Dtex535
Drives: 535i Msport
Very interesting
      03-25-2019, 11:27 PM   #7
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
So what are the gains?
      03-26-2019, 06:45 AM   #8
BurrNinja
Thats badass. It defeats the heatsoak issue going over the engine. I would buy, but its a bit out of my price range at the moment for air intake. Keep up the good work though!
Instgram @burninja
      03-26-2019, 09:33 AM   #9
doodlebro
Drives: '17 X3 35i
I like it, but you're taking a significant amount of airflow away from the radiator. Did you do any A/B testing on how coolant temps are with and without this setup?
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      03-26-2019, 07:02 PM   #10
$howtime456
301
Drives: BMW 640i
no testing yet. Can always work on upgrading the radiator to an aftermarket need be. Stock OEM intake was my main concern, spool time is much quicker and throttle response has increased since installing. Have to hit the rollers and dial in everything.
N55 GENERAL
David Shoup Tuned
      03-26-2019, 07:04 PM   #11
$howtime456
301
Drives: BMW 640i
yes, removal of the stock intake i was amazed. Thanks
N55 GENERAL
David Shoup Tuned
      03-26-2019, 08:07 PM   #12
doodlebro
Drives: '17 X3 35i
If you can test it and provide some data, I'd appreciate it. I've contemplated shifting over to this setup in my X3 (similar packaging to the F10) but I am always weary due to the radiator being blocked and air being sucked from all sides.
Current mods
      03-26-2019, 10:18 PM   #13
BurrNinja
So much more room on intake side to work with.
Instgram @burninja
      03-28-2019, 08:00 AM   #14
harris69
Dayum!
      04-04-2019, 12:09 PM   #15
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
Good stuff man!
      04-05-2019, 08:14 PM   #16
$howtime456
301
Drives: BMW 640i
thanks man
N55 GENERAL
David Shoup Tuned
      04-05-2019, 10:12 PM   #17
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I would consider this if it gave a nice loud intake sound and didn't cause the car to lose power (wouldn't need to make power). Better throttle response and faster turbo spool would be enough for me. $575 is steep though.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      04-05-2019, 10:50 PM   #18
neejay
Drives: 2011 535i M-Sport
Yeah, I'd love to hear a sound clip. I'd be down if there were no negatives, but as you stated, the price...damn. But I get it, custom fabrication costs $$$
      04-06-2019, 12:51 AM   #19
lsturbointeg
stats/data needed to take in account the price you're asking for
      08-14-2019, 09:29 PM   #20
super51fan
Drives: F10 535i
Can you reupload the images? I am not seeing them
      08-15-2019, 04:25 PM   #21
Duckysaurus
Duckysaurus's Avatar
42
Drives: 2021 G05, 2014 F10, 2009 E90
2014 BMW 535xi  [8.50]
2009 BMW 328i  [0.00]
If you got photos and it works well, I'll be down for it. (Out of NYC also.)
      08-17-2019, 12:30 PM   #22
$howtime456
301
Drives: BMW 640i
dont know why this keeps happening. Will reload back tommorrow
N55 GENERAL
David Shoup Tuned
