2010 2011 BMW 5 Series Forum F10 DIY Decatted DownPipe plug and play O2 Fix |
04-29-2019, 11:54 PM | #1 |
Rep 1,442
Drives: 2011 535i 6MT
I've never done a tutorial before, and because I didn't easily find a plug and play fix I thought I'd share what I ended up doing on my F10 N55 and what I learned. This whole thing cost me less than 200 bucks and I'll include links to everything below.
I'm assuming that you have a head on your shoulders and I'm not going to walk you through every single detail but give you enough info to get the job done. I probably screwed up on some things, so if you have any observations feel free to call me out. Thanks! Backstory: Bought this car from some rich lawyer for dirt cheap. 14,750 and only 71k and it's a true 6 SP. Thought it was a great deal but I later found out it had no cat (which I would have done anyway) and he never disclosed anything. It should have been a clue he let me keep his plates and that the OBDII port door was hanging open from him clearing the codes before my test drive. Luckily it has about 4k in exhaust and ECU mods I would have done myself. I need to get through emissions where they will only do a visual (that I already passed) and plug into my ECU for a readiness check with no codes. To fix properly the Catted DP from BMW was roughly 1800 not including labor, no thanks. Disclaimer: I am not a mechanic, and I really have no idea what I'm doing, so if you take my advice, don't come looking for me. If you learn from my mistakes, that's more of the point here! Remember, I'm really not that smart, I'm just good at repeating smart things I've read. Symptoms: ECU Throwing PO13E and/or P013A codes due to the fact that you had to get rid of your cats because of an allergic reaction that isn't your fault at all. Root Cause: For the POST CAT O2 sensor, the ECU is looking for a fluctuating reading from .75 (richest acceptable value) up to .95 volts (leanest acceptable value). As implied in the previous sentence, your ECU will adjust fuel based on the feedback from this Sensor, so it's nice to have an adjustable simulator. Advantage of this fix:
OK so here it is: Get your stuff together:
Prep for the job
Install: Location: It's recommended you install this away from heat. This thing gets HOT. So I decided to run the wires across the back of the firewall and put this thing up front near the air intake on the DS. Wiring: The module has 6 wires coming out of it. Black for ground - I just loosened the bolt on the brace and secured it there.
Startup: Remove or disable any ECU modifying equipment.Parts List: O2 Simulator: https://www.magnumtuning.com/en/deta...lator/bmw/535i 02 Sensor to Harvest Harness: https://www.ebay.com/itm/O2-Oxygen-S...72.m2749.l2649 OBD II BT Scanner: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 OBD II App: https://www.obdsoftware.net/software/obdfusion Thanks for reading let me know if you have any questions. |
04-30-2019, 07:52 PM | #2 |
Rep 151
Great work for what it is. That said, why not just get a proper tune (BM3/MHD) that hides the code and gives you proper/active calibration for not having a cat?
05-01-2019, 07:55 AM | #3 |
Rep 1,442
Fair question. Hiding the code doesn't get me through emissions in TN. They have to plug in and see the ECU in ready state and no codes. If I just mask it, then that doesn't help.
Long term, I'm looking at a turbo upgrade where I'll get it tuned properly, so this is just so I can get my plates. Or maybe I'm misinformed - if I flash with one of those mods, would my OBD2 port be open and available for them to scan, would they not see anything? Would the car reach ready state? |
05-01-2019, 09:24 PM | #5 | |
Rep 151
05-02-2019, 11:06 AM | #6 |
Rep 1,442
Oh well, that would have been nice to know 2 WEEKS AGO, lol... thanks guys.
06-21-2019, 09:06 AM | #7 |
Rep 1,442
Quick update for anyone reading this... It passed emissions and got me into readiness state. Also, even after re-chipping the car and leaving the simulator plugged in it has not thrown a code. It shows some pending codes, but nothing has moved to permanent yet which will throw the CEL.
06-21-2019, 06:18 PM | #8 |
Rep 1,299
I just passed the emission as well. All I got is a spacer on my downpipe that does the trick. MHD by default disables the Catalytic converter check, so you have to make sure that OEM/Catted-DP tick is checked.
06-22-2019, 05:43 AM | #9 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Why don’t you guys use 02 sensor spacers? To trick the 02 sensor reading.
08-12-2021, 12:16 PM | #10 |
King of NYC
118
Rep 176
Awesome writeup, thank you. I'm looking into doing a similar CEL solution. I'm assuming this is still running along fine?
I was going to go with another solution by A74 (can't spell out the full name here, forum edits it) but it doesn't seem to work with the more recent BMWs. So the box only sends signals upstream, to where the O2 sensor plugs into the car, correct? There are no downstream connections (towards the downpipe) from the Magnum tuning box I assume? I'm asking because I'm trying to do a plug in solution like you and not hack up the O2 sensor wiring. All I'll need is the female side of the O2 harness as a donor to splice in?
2014 BMW M5 Competition
MCB on Silverstone |
08-12-2021, 12:20 PM | #11 | |
Rep 1,442
08-20-2021, 04:04 PM | #12 |
King of NYC
118
Rep 176
I have a question about how you tapped in for the 12V source. You said you tapped the center wire of the plug. Which wire was it? Do you mean the O2 heater wire for the sensor itself? If not, can the O2 heater wire be used as a 12V source?
I have seen in some places it's been used this way. And somewhere else it's been said not to tap this wire and use an independent switched 12V source. If I had to find another source it wouldn't be too easy, using the O2 connector itself is much easier. But I'm not going to risk damage to me DME's if that's the concern.
08-20-2021, 04:09 PM | #13 | |
Rep 1,442
rockyfeller117.50 |
08-20-2021, 06:30 PM | #14 |
King of NYC
118
Rep 176
Thanks, ok so you went with an external source. Any reason you didn't opt for using the O2 sensor heating wire that's right in the O2 sensor harness itself? Is it safe to use?
08-21-2021, 12:41 PM | #15 | |
Rep 2,590
2015 BMW 535xi
08-21-2021, 12:48 PM | #16 |
Rep 1,442
I couldn't say… sorry!
08-21-2021, 12:54 PM | #17 |
King of NYC
118
Rep 176
Ok no worries.
After looking at Magnum's instructions they specially say not to tap the O2 heater power so I won't. Pretty sure it's risk to the DMEs and not worth it.
08-21-2021, 12:58 PM | #18 |
Rep 1,442
Why are you not just doing mhd?
08-21-2021, 03:19 PM | #19 |
King of NYC
118
Rep 176
My car is under extended warranty and I don't want to void it. Otherwise I'd do a tune in a heartbeat.
08-21-2021, 06:50 PM | #20 | |
Rep 1,442
09-10-2021, 11:52 PM | #21 |
King of NYC
118
Rep 176
I've did the install a few days back and it hasn't been successful so far. I know it's all wired up properly because the blue LEDs light up on the modules and I can see the simulated voltage readings when checking them with an OBD app. So that means the signal is going to the DMEs and it's all wired up properly for sure.
The modules are set at .95V from the factory and I can see the expected fluctuation up and down close to zero on the app. But I still got the CEL. I tried adjusting and clearing the code multiple times. I actually tried in .5V increments from as low as .65V all the way up to 1.05V. I was thinking that perhaps there was some magic value at which it might work? No dice. No matter what the CEL kept coming back. So Brow, did you actually have to adjust the voltage on your car? If so, what value worked for you? And the other thing that's stumping me is that by wiring it the way we are instructed to, it means that we're effectively cutting the power to the O2 heater wires. My car was showing this error code as well. Was it showing a code for the "O2 heater circuit not working" on your car? I'm not sure if this in itself would produce a CEL light or whether it would affect O2 sensor readiness? If so, that poses a 2nd problem for getting this to work properly. But I'm less worried because it's an easier solution if that's the case. Just run separate wires directly to the O2 sensor so that the heater wires remain intact. There's no impact on the O2 heater element if there are cats or not. Just to be clear, my car is a F10 M5, so it's a different engine than yours. S63. For the most part, from people who have tried, the consensus seems to be that the DMEs are hard to trick and so far nothing has worked. Perhaps the voltage fluctuations these type of simulators make are far too uniform and unrealistic so the car detects that something is not legit. That's my hunch. Any input or advice before I throw in the towel?
09-11-2021, 06:59 PM | #22 | |
Rep 1,442
