2010 2011 BMW 5 Series Forum F10 Need help identifying wires |
11-07-2019, 08:52 AM | #1 |
Rep 423
Ok, I pulled this side panel off to look for a temperature sensor in my driver's side AC vent, when I noticed the disconnected wires here. Does anyone know what this should be connected too? Was something removed from this space?
I've got a 2011 535i .
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
11-08-2019, 08:56 AM | #3 |
Rep 8,113
Ditto above...some aftermarket or left over wiring from a previous owner's install was the first thing that made me go hmmm. I can't ever recall BMW grounding anything with a screw...plus BMW normally uses a brown wire for ground and it usually runs back to some grounding point (like one of the usual ground connectors or combs).
See #2 & #4 below...these are comb connectors which can usually be shortened to the desired amount of poles...this is what you see multiple ground wires connected to around the vehicle: {here's another example of how BMW groups a bunch of ground wires to one large connector "comb"}
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-08-2019, 07:38 PM | #6 |
Rep 4,571
Something removed by previous owner. Follow the +12V wire (the one with the butt connector) and see where the other end connects. If feasible remove it. De-trash your car.
2023 840GC | 2021 740i | 2019 X3
FrannieMoral20176.00 |
