2010 2011 BMW 5 Series Forum F10 Dealer recommends to do decarburization... |
11-12-2019, 12:22 PM | #1 |
Rep 151
Hello folks. Dealer recommended to perform decarburization every 30k miles and they said they got a promotion going for $200. Is this worth it? Or there's an alternative to this that would be more effective and perhaps safer for your car? Any advise would be appreciated. TIA.
11-12-2019, 01:36 PM | #3 |
Rep 151
11-12-2019, 02:12 PM | #4 | |
Rep 61
I seen a post by Sophisticated Redneck where he was doing that and it looked like he tore the whole head down. For them to only charge $200 for it seems like a helluva steal. |
11-12-2019, 07:21 PM | #5 |
Rep 5,610
They run a cleaner through the intake system to hit the back of the valves and through the injectors to clean them. I had it done to hopefully head-off any future need for the much more expensive (and intrusive) walnut blasting. I'll have to wait and see if this was a wise choice.
11-13-2019, 11:05 AM | #6 | |
Rep 151
Thanks for those who shared their inputs. Appreciate it as always |
11-14-2019, 10:11 AM | #7 |
Rep 246
I would go buy a bottle or two of Techron fuel system cleaner and save the additional $190.00 since this is probably what the dealer is going to do.
Good luck. |
11-14-2019, 03:52 PM | #8 |
Rep 92
Dealers make money, that's what they do. I heard of decoking an engine decades ago, 1950's or 60's, perhaps due to engine design and fuel quality back then. I know diesel generators need to be run at full load to clean the engines to allow them to operate properly when needed, it's called maintenance. But regarding BMW modern petrol engines I have never heard it mentioned apart from in this original post. Regarding diesel BMW engines you just drive them for long distances every now and then. I know with my engines I drive them hard every now and then, to clean the soot and "carbon" out of everything. And I know my mechanic cleans out the turbos due to oil residue from a over-boosting mod.
$200 is 200 dollars, you can spend it on something else, beer comes to mind. I'd say just drive your car hard in sports mode or manual to gets the revs up and make the engine sing and clean itself as it does its job. The engine will love you for it. And remember engine speed is not to be confused with road speed, that's where the gearbox comes into play. |
11-14-2019, 11:46 PM | #9 |
Rep 5,610
It's different now. With direct injection no fuel touches the back of the valve so it doesn't get cleaned. The dealer shoots cleaner into the intake track which cleans the back of the valves.
11-16-2019, 11:54 PM | #10 | |
Rep 1,564
Walnut blasting is normally around 600-800ish for 6cyl BMW engines, and about 3000+ for the N63/S63 and the TU variants due to having to remove the engine (I removed the heads as I don;t have a car lift and I also wanted to clean the combustion chambers and pistons) All direct injection engines will need some form of carbon cleanup on a long enough time line but some are worse then others. The N63 is one of the worst, with its extreme operating temps and absolute joke of a CCV system...well just look at the pics below. A proper catch-can setup with Bronze Micro-filters will greatly reduce the carbon build-up. The Bronze Micro-filters are key. Ironically most catch-cans dont have them but the 25 dollar cheapies off Amazon include 50 micron bronze filters and work better then catch-cans costing 10 times as much. |
11-17-2019, 08:35 AM | #11 |
Rep 3
This may sound a bit naive but why not ask the dealer exactly what they are going to do.
I always ask what the process is. If they are reputable, they will explain in detail or maybe have a pamphlet. I too drive my car long distances to burn off carbon. |
11-17-2019, 01:43 PM | #12 |
Rep 246
So the OP should go buy the Seafoam kit that does the same thing and still save most of the money.
11-25-2019, 06:54 PM | #14 |
Rep 2
If no fuel touches the back of the valve, how does the valve get dirty enough to need this "treatment"?
11-25-2019, 11:50 PM | #15 |
Rep 5,610
The PCV system recirculates blow-by gasses back into the intake track. This "contaminated" air has oil particulates that stick to the back of the hot valves. Since no fuel (which has detergents to clean these deposits) passes over the back of the valves the carbon just builds-up. Search walnut blasting or N54 carbon build-up. The N55 has better engine ventilation so carbon build-up isn't near as bad as the N54.
11-26-2019, 08:14 AM | #16 | |
Rep 1,564
I think if you start using it on a regular basis on a new engine like every oil change, it could really help keep the deposits down, but after 60k+ of hard deposits are set in, one little bottle isnt going to do much. Watch the you tube videos and decide if its worth it to you. |
