| 03-09-2020, 07:09 PM | #1 |
![]() ![]() ![]() 279
Rep 424
I have 2011 535i N55 with roughly 132k miles. I recently downloaded Ista+ and have been learning the diagnostics system. When I check the control tree I have a permanent code 133E10 that shows in the DME. This code has never pulled when using regular OBD2 scanners. Can someone shed some light on this. Is this a typical issue with the N55 motor? Is this something I should really be concerned about or is it no big deal? Not sure why the code isn't present when scanning normally.
![]() Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 Shoup custom MHD tune, RVG Highflow Catted DP, CP, Boost Pipe and FMIC, FrankenTurbo F55 turbo, BMS Port Injection with 550CC, S63 Injectors, Walbro 455 LPFP and Walbro 520 LPFP, SSR GT03 Wheels, BC Coilovers, 6WB Cluster, BimmerhausPerformance Intake and custom LSD. |
| 03-10-2020, 10:16 PM | #2 |
Rep 424
Ok, well I guess we can delete this thread. I used Ista+ to activate the valvetronics and relearn the vanos limits. Once complete I was able to delete the 133E10 code.
Mnasty940.00 |
| 03-10-2020, 10:20 PM | #3 |
Rep 496
You don't delete threads like this. You've figured out the problem. This might help someone who is experiencing the same issue.
| 03-12-2020, 10:18 AM | #4 |
![]() 560
Rep 1,490
Drives: F10 S55, E93 M3, E89 N54
Is your car running better now?
| 03-12-2020, 10:23 AM | #5 |
Rep 424
Yes, I feel like all my idle gremlins have been corrected. It seems this valvetronic issue and vacuum leak with my Valvecover was causing the rough idle.
As a side note, when I replaced my spark plugs and gaskets, I pulled both Vanos solenoids and cleaned them thoroughly.
| 03-12-2020, 12:45 PM | #6 | |
![]() 560
Rep 1,490
Preferably without background music... lol jk. |
| 03-12-2020, 12:48 PM | #7 | |
Rep 424
| 03-12-2020, 03:42 PM | #8 |
![]() 560
Rep 1,490
OK thanks!
| 03-28-2025, 02:55 PM | #10 |
Rep 9
Hy hello everyone, i have the same Code 133E10 , i need to change the valvetronic or not?
Can i delete or Activate this ? My car is a bmw 335i N55 f30 2013 and still running good, . Thx |
| 05-21-2025, 05:08 PM | #11 |
Rep 11
I had the same code appear (also 2013 335i) the other day with no other symptoms at all. Took it to a shop for a full diag and they noticed nothing wrong as well as it passing the full ISTA test plan for valvetronic sweep. They have cleared the code and told me to continue driving as usual as with no other symptoms there’s not much you can do unless you want to replace the shaft, motor, harness etc (around 3-4k with labour) preventively.
| Bookmarks |
