04-08-2020, 09:59 PM | #1 |
Rep 529
Testing for boost leaks
I found my leaks and back on track for a 22+ PSI tune. Also check out where i found the leak!
Maybe this will helpful to some since I couldn't find specifics on our motors on YouTube on how to do this. One thing to note is I could only raise the pressure to 14 PSI because t bolt clamps suck. I'm going to get worm clamps and pressurize my system to 25psi
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
04-09-2020, 02:15 AM | #3 |
Rep 529
A bunch of plumbers tape around the tap-screw worked.
04-09-2020, 04:05 PM | #4 |
Rep 2,595
Might want to normalize the audio on your videos. The intro was loud as hell but then the actual video was mad quiet.
2015 BMW 535xi
Bmwdoubles_194.00 |
04-09-2020, 06:05 PM | #6 |
Rep 529
I noticed that too. I'm a noob vlogger. I think I know how to fix it without replacing the video though. Thanks for the feedback
04-10-2020, 01:57 PM | #7 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
WOW that is the lamest leak ever... maybe you shouldn't use 3" screws to mount your bracket?
Bmwdoubles_194.00 |
04-10-2020, 02:24 PM | #8 |
Rep 529
Lol i like placing 6" wood screws in my manifold. Seriously though, I'll be replacing the manifold.
12-11-2020, 11:02 PM | #9 |
Rep 1
I'm having a similar issue. Boost maxes out at 14psi. Will be performing a boost leak test when my kit arrives next week. Interested to see if we are having the same issue, or if i just did a crappy job installing my FMIC. Great video by the way.
12-15-2020, 07:30 AM | #10 |
Rep 1,445
Are you on a stock turbo?
