4 Series
Technical Topics DIYs and Coding Discussions Sunroof issue
      04-15-2020, 11:35 PM   #1
aghanty
Drives: BMW 330E
Sunroof issue
Hi,
I'm having an issue with my G20 330e sunroof.
It has stopped working since yesterday. It is in the closing position and wont open. Car is 4 month old.
After some research, I did a reset by holding on the tilt button for 20 sec. Now the tilt is working but the shade is still in the closing position and the sunroof slide is also not working.
Any idea?
      04-16-2020, 09:24 PM   #2
Ghozthunter
Eleet Tech
Ghozthunter's Avatar
Drives: a bimmer
I had this happen to me aswell. Keep sliding the open button many times until it opens again. If the shade is stuck on the open position try sliding the button to close many times. Has not happened to me again so far.
      04-18-2020, 04:59 AM   #3
advrider6510
advrider6510's Avatar
Drives: E36 M3, F80 M3, Ford Mustang
Hello,
Just happened to come across a video from you tube about this sunroof issue..
... I am not sure if this is the exact problem or not.. thought it might help
      04-19-2020, 01:21 AM   #4
aghanty
Drives: BMW 330E
Thank you all for the reply but it was not successful. I will take it to BMW after the lockdown.
      04-19-2020, 02:01 AM   #5
advrider6510
Sorry to hear about that... Would be really helpful, if post your resolution you can update us here. We all would really like to know about the issue and its resolution in detail
      04-20-2020, 08:54 AM   #6
aghanty
Drives: BMW 330E
Yes sure. In 2 weeks time
      04-20-2020, 05:23 PM   #7
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Could be worse, stuck in the open position.
      06-03-2020, 10:17 AM   #8
aghanty
Drives: BMW 330E
They reprogrammed it they said. Not mechanical issue I think. Working ok now.
      06-03-2020, 03:51 PM   #9
Phippsy81
Phippsy81's Avatar
Drives: G20 330i M Sport Plu
I have an issue with closing my sunroof, from tilt is fine, but in fully open it won't close on the one touch... It almost closed and the pops back open, kind of like the anti trap is kicking in?!
It will only close if I keep using small presses on the close button once it gets close to closing!
J
330i M Sport Plus
Previous- 435D M Sport
      06-05-2020, 09:32 PM   #10
808G80
808G80's Avatar
103
Drives: 2021 BMW M3
I have the same issue. I bought my M340i back in october 2019 and it happened within 2 weeks ownership. Sunshade would not close. BMW of Maui said they fixed it but it happens intermittently now. Its getting worse. Just today, I could not open the moonroof at all. I heard a ticking noise coming from the moonroof switch and it opened fine. Then it wouldn't close. As soon as i arrived at the dealership, it started to work again.
      11-05-2020, 06:01 AM   #11
tiagotrovao
Drives: BMW 320d (G21)
G21 sunroof trouble
Hi group!
The sunroof in my G21 stopped working, and message error says it's 'Impossible to close due to rain sensor' (the sunroof is closed btw). Tried the 15 second reset but no change, doesn't reset, doesn't tilt, nothing...
Due to take it to bmw under warranty, but would love to know if anyone experienced this, and how was it solved.
Thank you,
Best,
T.
      11-26-2020, 05:29 PM   #12
mdesilva
Drives: 2020 330xi
My sunroof was stuck in the open position. Fixed this issue by driving around the car for about a mile, turning off the car, locking it, unlocking it, opening all 4 windows by holding the unlock button, and then restarting the car. Sunroof closed up right away upon pressing the close button.
The core part of the solution I believe is to turn off the car and lock it, and then unlock it and turn it on again
      02-27-2021, 11:43 AM   #13
Sunset330i
Drives: BMW 330i M Sport
Hi,
Any idea?
I have the EXACT same problem. 2020 330i with 12k miles. Unacceptable.
ztech132.00
      02-27-2021, 04:27 PM   #14
luv2learn
luv2learn's Avatar
Drives: BMW 340ix MSport
I had a similar issue with my 21 m340ix. Wound up being faulty “rain guard”. I found calling BMW direct was very helpful. Especially since I’ve read up on all the sun roof woes here, I didn’t want to be a victim. They coordinated with the dealership and was more than willing to see the issue through to my satisfaction.
Tags
sunroof
g20
