4 Series
Technical Topics DIYs and Coding Discussions Brakeforce flashing
      05-22-2020, 01:19 PM   #1
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
Brakeforce flashing
Did anyone code the brake light flashing on the US version G20? Thanks.
      05-22-2020, 11:55 PM   #2
minakoto00
minakoto00's Avatar
Drives: G20 330i xDrive Luxury Line
I would like to code it too, anyone knows how to do it?
      05-26-2020, 04:43 PM   #3
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
Try this in BDC_BODY (CAFD 7083):
Set GefahrenBremseLichht_Typ from nichtAktiv to bremselicht_blinkend
After doing this, if you stop suddenly, the third brake light will flash
Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
VipinLJ1941.50
      05-26-2020, 10:09 PM   #4
TTG
TTG's Avatar
Drives: M340
Its a menu option on BDC on Bimmercode.
I have activated it and tested it and it works.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
A6bullet337.00
      05-28-2020, 01:49 PM   #5
howiegu
Member
howiegu's Avatar
Originally Posted by RSnic View Post
Hi,
Hope that helps!
Perfect! Thanks for pointing to the directions.
      05-28-2020, 03:21 PM   #6
AP
AP's Avatar
2777
Drives: G30 M550
Pretty sure all brake lights are supposed to flash? At least that's what I've seen on various you tube videos and the like
      06-02-2020, 02:00 PM   #7
howiegu
Member
howiegu's Avatar
You're talking about the brake lights flashing with turn signals.
This is to code the Brake Force flashing, where the brake lights flashing rapidly under hard deacceleration.
      06-07-2020, 03:05 PM   #8
Swagasaurus-R3X
Swagasaurus-R3X's Avatar
Drives: BMW M340i
Figured I would join in on this. I have a 2020 G20 M340i and changed the GEFAHRENBREMSLICHT_TYP to the blinkend setting. Went out and tested it and nothing. Im guessing there has to be a considerable amount of braking in order for it to activate. Anyway to activate it regardless of force? I have seen it done on the F30.
FYI my general settings under the main ecu menu for BDC Brake force display is set to 5km/h and to weak braking.
      06-08-2020, 01:48 AM   #9
dwlc1983
Drives: 2020 330xi
I'm having the same experience. I changed the brake force display to aktiv and also on the 5km/h (weak braking) setting on the Bimmercode face module and tested with no flashing. Tried on my friend's g20 as well, also with no results. Interested to know what people did differently to get it to work.
      07-06-2020, 12:10 AM   #10
jason0510
Drives: BMW M340i
Same thing for me. Canadian model and changed the GefahrenBremseLichht_Typ to bremselicht_blinkend and changed to 5m/s^2 and 10km/h break speed something like that and coded nothing happened after several test run. Not sure if north american model is not allowed? also my connector is OBDLink MX+
      07-06-2020, 10:22 AM   #11
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Don't quote me but I believe they might of removed it from the US/Canada spec models.
Some might notice that in just the last generation of vehicles, US-spec vehicles used to be fitted with a feature called "Brake Force Display" in the US; where when you stomp hard on the brakes, an additional area in brake light illuminates.
If you notice, that feature has been removed from the G-Generation of BMWs.
I guess the assumption is that brake lights being LEDs now, they are much brighter than halogen for the past, so BFD is not necessary or no longer implemented in some cars.
This might be the possible reason the feature is not longer available for coding, regardless if it's flashing or an enhancing brake light surface area.
      07-06-2020, 02:00 PM   #12
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Euro Brakeforce (blinking brake lamps) can be enabled in our NA vehicles but the only way I found was to VO/FDL Code the tail lights to operate like the Euro tail lights.
Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
      07-06-2020, 02:46 PM   #13
Poochie
Poochie's Avatar
Drives: 2016 M2
Larry
Everyone else that did it, even by VO coding, claims only the high center mounted brake light flashes, on NA-spec vehicles, not the lower left/right brake lights.
Where you able to confirm with certainty that all the brake light flashes, with a VO coding or region change?
      07-06-2020, 03:06 PM   #14
larrylam646
Yes, I have confirmed. You have to code Euro tail light operation. Coding for my vehicle - https://g20.bimmerpost.com/forums/sh...7&postcount=55 or https://g20.bimmerpost.com/forums/sh...5&postcount=60
For jk1112 coding, but I do not know if he has confirmed correct Brakeforce functionality - https://g20.bimmerpost.com/forums/sh...1&postcount=69
Poochie9104.50
      07-06-2020, 03:14 PM   #15
Poochie
Poochie's Avatar
Drives: 2016 M2
Yes, I have confirmed. You have to code Euro tail light operation. Coding for my vehicle - https://g20.bimmerpost.com/forums/sh...8;postcount=55 or https://g20.bimmerpost.com/forums/sh...8;postcount=60
For jk1112 coding, but I do not know if he has confirmed correct Brakeforce functionality - https://g20.bimmerpost.com/forums/sh...8;postcount=69
Good to know and thanks a lot
If would humor me, just one other question; The older generation of BMWs had a separate subset of lighting in the taillights, that illuminates when US-Spec "Brake Force Display" (Area Enlargement) is trigged.
That expanded brake light area is what the ROW uses as "rear fog lights."
Since "rear fog lights" LED clusters do not exist in US Spec hardware anymore, I'm assuming by extension, the additional coverage of emergency brake lighting (BFD - Area Enlargement) no longer exists on the G-Generation of vehicles?
      07-06-2020, 03:51 PM   #16
larrylam646
I think you are correct. I do not believe the G20 tail lights come with BFD-Area Enlargement LED clusters like the F-Series platform.
Poochie9104.50
      08-02-2020, 04:19 PM   #17
howiegu
Member
howiegu's Avatar
Is the flashing braking force only relating to the 7083 coding? Thanks.
      08-02-2020, 05:37 PM   #18
larrylam646
As I have stated in my earlier posts, I only know of one way to get brakeforce to work properly.... code the rear tail lights to work like the ECE/ROW tail lights.
You have one of two way of performing this task as presented in my earlier post. Coding involves 7083 and 5665.
Larry
      04-17-2021, 09:15 AM   #19
cowymo
Drives: 2021 BMW M440i XD
Just managed to discovered the setting for G22.
It's under BDC_BODY3, 3075 LceMaster. Not sure if it's gonna work, but surly just setting it via primary page on Bimmer code doesn't work.
      02-15-2022, 02:01 PM   #20
howiegu
Member
howiegu's Avatar
Did it for for G22? Thanks.
      07-12-2023, 01:23 AM   #21
An2610
An2610's Avatar
Drives: Bmw g05 Bmw e66
Was able to code it on G05.
Only the 3rd brake light is flashing and it automatically disables hazard flashing after emergency braking.
g20
