| 07-12-2021, 02:10 AM | #1 |
![]() 15
Rep 100
F10 Key fob
Hello, I have a key fob that belonged to a 2016 535D. I bought the car a couple of years ago and returned it within a week because it was all kinds of jacked up. I just found that I still have one of the keys. I'd like $50 for it. Thanks. Edit: I've updated the price to $25. I have no use for this thing and don't want to just throw it away. I'm pretty sure I have come across threads before with instances of reprogramming or coding these to work. Last edited by E90angeleyes; 07-15-2021 at 07:37 PM.. |
| 07-12-2021, 07:18 AM | #2 |
Petrolhead
618
Rep 880
Drives: 24 IS500 F/24 X3 M40i
FYI. Key fobs can't be reused on another car. Beside the fact that the metal key is already cut, the transponder cannot be reprogramed once programmed for a car. Unless someone desperately wants it for the plastic shell, it's pretty much useless.
2024 Lexus IS500 F Sport
2024 X3 M40i 2008 Z4 3.0si 6MT (sold) 2014 550i (sold) 2011 Z4 35si (sold) |
| 07-12-2021, 01:25 PM | #3 |
![]() 15
Rep 100
I thought it could be reprogrammed. Not by BMW (can, but won't), but by a coder.
| 07-15-2021, 07:37 PM | #4 |
![]() 15
Rep 100
| 07-15-2021, 07:46 PM | #5 |
Rep 63
Drives: 2012 BMW 535xi
You can do it with a Yanhua Mini ACDP.
| 07-16-2021, 11:04 AM | #7 |
Rep 63
| 09-07-2021, 02:20 PM | #8 |
![]() 5
Rep 39
I believe the dealership can reprogram them for less than $200.
| 09-07-2021, 07:16 PM | #9 |
Apprentice
100
Rep 498
I'm surprised by the misinformation. spielnicht is the only one correct.
A random key cannot be programmed to a random car. When a car is produced, there are 10 transponder chips manufactured that match the FRM and other modules in the car. 2 end up in keys, the rest stays with BMW. If you order a replacement key from BMW, one will be made with the existing transponder chip and cut to your car, up to 8 times. After that you will need new FRM module and a new collection of chips. That's why the aftermarket solution linked above contains both the key chip and the replacement modules. A key from a random car cannot be made to work to start the car (but it might be programmed to open doors/windows, which is separate from engine immobilizer). It's either a paperweight or can be used to source a shell. |
| 09-08-2021, 08:10 AM | #10 | |
![]() ![]() ![]() ![]() 247
Rep 705
Like it's been said, this is great for the shell if yours is beat up and just want to swap the guts!
2011 F10 Shuenk N55+ Turbo'd is SOLD. Now building a 2018 Golf R on E85! ![]() |
| Bookmarks |
