11-15-2021, 11:11 AM | #4 | |
Rep 11
but, In my case the connectors did not fit, so I used adapter cables. I used the HK subs from an F20, because they have the same impedance (2 ohms) as the original hifi subs in the f10….. the original f10 HK subs have an impedance of 8 ohms….. so depending on which amp you are going to use, you must consider your choice…. My expectation (and this is not tested in reality) is that the original hifi amp is not able to handle an 8 ohm sub…. Power to the subs will be decreased with factor 4!! (8 ohms is 4 times higher than 2 ohms) Good luck!
BMW 528i LCi (F10) 2014
BMW 525d LCi (E60) 2007 BMW 320d (E46) 2001 BMW 320i coupe (E36) 1994 |
