11-25-2021, 04:40 PM | #1 |
Rep 11
Knocking sound
Hey guys, I would like to have your opinion on a weird noise that my car is making, video attached…
Is a 2012 n55 112000 miles and is making the same noise since I bought it 1500 miles ago, I changed the oil at BMW dealer 1200 miles ago. The car is running perfect apart the noise. Thank you |
11-25-2021, 08:03 PM | #2 | |
Rep 1,128
11-26-2021, 02:10 PM | #4 |
Rep 1,873
As far as I know the noise when you open the oil cap is "normal" / typical vacuum pump noise, as bad as it sounds. On my N55 when the engine is cold started it has a little squeak in it too until there's a little heat in the engine. When I was worried about it I searched a lot and found it's "normal" noise for the vacuum pump.
11-27-2021, 12:11 AM | #5 |
Rep 2,591
Based on the initial two videos:
Rod knock.
2015 BMW 535xi
