| 04-03-2022, 02:41 PM | #1 |
Rep 118
Turn Signal Clicker Sound is Noisy
I have been looking all over the place of any info related to this issue, there is only one guy that made a post about it in 2015 with no replies.
My issue is that the turn signal clicking sound is a bit too noisy and clicky as compared to our 2015 3 series. It maybe due to wear and heat (here in summer it can reach up to 49 degrees C). I am looking for any info that can help me reduce the clicking noise and revert it to new. Cuz currently it sounds like a 1995 corolla turn signal. |
| 04-03-2022, 09:32 PM | #2 | |
Rep 6,864
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i E91 [10.00]
2009 BMW 328i E91 [7.56] 2006 BMW 330i [8.17] 2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2011 BMW 528i [9.07] |
https://f30.bimmerpost.com/forums/sh....php?t=1279640 |
| 04-06-2022, 07:18 PM | #3 | ||
Rep 153
Drives: 2014 BMW 528i
Tri Nguyen
| 04-24-2022, 10:40 AM | #5 |
Rep 9,826
The turn indicator “tone” is one of the acoustic sounds made by the instrument cluster.
Some of these sounds can be turned up or down on some versions of iDrive. Have you tried adjusting this parameter in iDrive to see if it tones down the VOL of your turn indicators? I made a video of the cluster’s ACOUSTICS…and you can hear the turn indicators which are the last ones that you hear approx 36 seconds into the video: Again, the car’s GONG volume can be adjusted…see the pics below for where it is located in iDrive (if you have ID4). See if adjusting your GONG will tone down your turn indicators:
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-24-2022 at 10:47 AM.. |
| 04-26-2022, 02:26 PM | #6 |
Rep 9,826
FYI…I can answer my own question in the post above…the iDrive VOLUME adjustment for the GONG does NOT adjust the sound of the turn indicators…it only changes the sound of the GONG itself.
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
| Bookmarks |
