2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Want my Brake Lights to Pulse/Strobe...any suggestions?
      04-04-2022, 07:19 PM   #1
SummerallGuard04
SummerallGuard04's Avatar
113
Drives: 2016 BMW 550i M Sport
My street is located at the bottom of a steep hill, on a curve. I'm always very careful of who is behind me when coming down the hill and getting ready to turn. I'll pump my brakes and put my turn-signal on slightly earlier than needed. I remembered that i have seen some cars have their 3rd brake light flash 3 times before it comes on solid, which i'm guessing is just something plug-and-play. But then i saw some youtube videos on strobing or pulsating brake lights and thought that would be neat, instead of just flashing. Wondering if anyone has any suggestions? I swore i saw an E39 m5 a few years ago that had all brake lights strobe when the brakes were depressed and thought it was the coolest retro-fit.
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black
2011 BMW 335i - Alpine White
      04-04-2022, 11:01 PM   #2
Check out the coding section for brakes. I don't remember what it's called, but flashing can be coded.
      04-05-2022, 04:42 AM   #3
SummerallGuard04
113
I was hoping there would be another way to do this, other than coding. I am unfamiliar with how to do any of that and don't have any apps or software.
      04-05-2022, 04:32 PM   #4
Coding is the only way. It is active in Europe and deactivated when shipped here.
      04-06-2022, 01:56 AM   #5
AP
AP's Avatar
3648
Drives: G30 M550
Yes the brake lights here in Europe, legislation has for a long time allowed them to flash under heavy braking.
I think they appeared on the e60 originally so have been around for quite a while .( thought I read that the e39 was going to have them but legislation never agreed in time so it didn't make it to that model)
Somewhere on the I internet you'll find the exact parameters that trigger this. I think it's a certain amount of deceleration and also possibly if abs is activated
      04-06-2022, 08:00 AM   #6
zvery777
zvery777's Avatar
Drives: 2021 M550
2021 BMW M550  [9.50]
I coded mine via Bimmercode, there are a few options available in terms of when you want them to flash.
      04-06-2022, 08:17 PM   #7
Unspec
Unspec's Avatar
1502
Drives: 2015 BMW 535xi
Even when coded in, the stock settings have it so flashing brake lights only happen under VERY heavy braking. Even if you change the setting so it flashes under any amount of braking deceleration, it's not a "blink 3 seconds and solid", it's "blinks until you come to a complete stop", which WILL annoy the hell out of other drivers. So the coding option, realistically, will not accomplish what you are seeking.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-10-2022, 11:03 PM   #8
Dking078
Loves Automatics
Dking078's Avatar
360
Drives: 2018 M2
As a driver behind some 'murican brands that adopted this and poorly done retrofits...
Please don't, it gets annoying really fast, especially in traffic.
Flashing under hard braking is factory and the best iteration for the situation.
2018 M2 [LBB / Blk]
2018 X5 50i [AW / Blk]
2016 550i [AW/ Blk]
      04-13-2022, 06:57 PM   #9
SummerallGuard04
113
Yeah, i agree. this is not what i wanted. moreso, just wanted the pulsating or strobing for like 3 secs and then solid. I guess i can look into the pigtail for the flashing 3rd brake light. i think it blinks 3 times and then stay solid...
      04-21-2022, 02:44 PM   #10
Johnkwick
Drives: F10 LCI
you can set the parameter in the deceleration section to reasonable value so it won't blink every time you press the brake pedal
you can set the minimum velocity parameter to activate the emergency braking light
and you can also set the parameter to determine when the brake lights will stop blinking (either complete stop or after your car is no longer under heavy deceleration)
