2010 2011 BMW 5 Series Forum F10 Emergency - Need Help To Manually Release Parking Brake on 2011 550i |
06-07-2022, 07:35 AM | #1 |
Rep 23
hello wonderful ppl,
i bought a 2011 BMW 550i that only came with the metal key, key fob is missing. i have managed to put the car in neutral, but the parking brakes have been engaged. How do i release the parking brakes. I have removed all the carpet in the trunk and looked for the parking brake string to no avail. can someone please help me locate the parking brake release harness. Another question, option #2, can i have the stealership program a new key fob? thank you, DoN |
06-07-2022, 09:56 AM | #2 |
Rep 2,637
Parking brake is electronic. Without the fob, you have no way to disengage it normally.
You'll need to take the rear wheels off, remove the parking brake actuator, and then use a torx bit to unwind the parking brake manually. Yes, you can get the dealer to program a new fob as long as you have documents proving you're the owner of the vehicle.
2015 BMW 535xi
06-07-2022, 01:49 PM | #3 | |
Rep 23
for now the tow truck driver using a wench to pull the car out of the trailer, i'm hoping no damage to the transmission. |
07-06-2022, 04:52 PM | #4 |
Rep 39
I dont remember the correct size, maybe a 8mm, but yiu can use a metric allem wrench to back the piston out for parking brake for each side.
You remove the parking brake actuator with the 2 torx screws to get acess then the hole is in the center of the caliper for the parking brake piston. When you do have a programed key fob and you activate the parking brake you will get an error. You will have to use wheel chocks to keep it from rolling though. Eric |
07-12-2022, 09:53 AM | #5 |
Rep 172
that's quite hefty for a key.
You could remove the CAS, send it over to someone who set it up with a key, way cheaper.. This is the key that I bought, they set it up locally for $150 usd https://www.ebay.com/itm/294094664890 Found this service, but have to ask about what options you have without a working key. https://www.ebay.com/itm/29434083714...EAAOSwJRxhxExU |
