2010 2011 BMW 5 Series Forum F10 New TPMS sensors not resetting |
09-03-2022, 06:19 PM | #1 |
Rep 175
I recently swapped 20's for 19's and had new TPMS sensors installed with new tires in the 19's. I drove home with the 19's mounted and the 20's in my trunk and back seat so when the TPMS sensors would not reset I assumed iDrive was still trying to connect with the sensors in the 20's that were not moving.
Now that my new 19's are mounted I've tried resetting the TPMS sensors a few times and it's not working. The problem is I'm 2 hours away from the nearest Discount Tire and shops in my area go crossed eyed when I mention BMW. I've been in the market for a good scanner tool and noticed that this one includes TPMS functions. Will this fix my issue? |
09-08-2022, 02:01 AM | #2 | |
Rep 262
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
