09-13-2022, 02:54 PM | #1 |
BimmerPost Supporting Vendor
9587
Rep 10,878
IND | RKP G8X M3 / M4 Enhanced Clearance Front Liner Set - New V2
While BMW left plenty of room to lower the ride height of the new G8X M3 and M4, they unfortunately did not leave enough clearance between the front wheels and the front fender liners to adequately space out the wheels for an ideal stance. The result is a brand new M3 or M4 with wheels that look sunken into the fender arches. The issue stems from the clearance between the front wheel and the cooling fins behind the heat exchangers mounted in the front bumper. In factory guise, trying to fit anything larger than 12mm spacers would result in rubbing when turning the vehicle. This was especially problematic in reverse as the downward angle of the fins would cause them to snap off when contacted by the tire. The RKP front liner set includes both left and right front liners that have been professionally modified to enhance the clearance where the heat extractors are located. And since OE BMW liner cores are used, these modified liners will fit just like your factory liners. NOTE: Installed photos show V1 mesh. New version includes honeycomb mesh. While these liners provide extra clearance whether using spacers or running aftermarket wheels, we cannot guarantee clearances with aftermarket wheel fitments and different tire sizes. Product Details:
The RKP G8X M3 / M4 Enhanced Clearance Front Liner Set may be viewed at the following link to our online store: https://ind-distribution.com/product...nder-liner-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
09-05-2023, 12:05 PM | #2 |
9587
Rep 10,878
