11-17-2022, 01:08 PM | #2 |
Rep 668
just a recommendation- most people do not have every trouble code memorized, and the grand majority of people will not take time out of their day to google all 7 codes to then be able to help you. If you could add what those codes are to your post, you will have a high probability of others helping you
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
Unspec1311.50 |
11-17-2022, 03:56 PM | #3 | |
Rep 214
The dealer suggested to get a new DME. I dont believe this. Maybe i am wrong. I request all the members here to plz help me. |
11-17-2022, 04:27 PM | #4 | |
Rep 214
1F0538 - DME, internal fault, safety function: Maximum total torque exceeded 21A110- Engine torque limitation: as the result of emergency operation request from control unit of electrical machine emergency operation manager 21A512- Start system, crankshaft starter generator: Timeout 220507 - High-voltage power management: Reduction of power consumption required by 12V electrical system 220560 - Emergency operation manager: Active short circuit due to DME fault 235410- Emergency operation manager: Request idle speed increase of electrical machine control unit D35A78 - Signal (status engine auto start, 230.1.2) invalid, transmitter DME/DDE |
11-17-2022, 09:16 PM | #5 | |
Rep 639
How old is the battery? I've seen multiple instances where a dying battery shows multiple codes for random errors. I could be wrong, but if it was my car and the original battery, it try replacing that and registering it through ISTA first. |
95blkmax216.50 |
11-18-2022, 05:48 AM | #6 |
Rep 214
11-18-2022, 04:40 PM | #7 |
Rep 214
Can anyone help me with this problem.
My wgdc stays around 100 and i cant acieve target boost. Can somone please guide. No boost leaks. Wastegate calibration is also ok https://www.bootmod3.net/log?id=6375...729bebbb69f0bc |
11-22-2022, 01:20 PM | #8 | |
Rep 2,595
2015 BMW 535xi
11-22-2022, 05:57 PM | #9 | |
Rep 668
MANNERISM- boost never even comes close to target boost. WGDC is maxed out so the DME is trying to achieve it but can't. Im assuming no traction issues as this is in 3rd gear and you had no throttle closure. HPFP is plenty happy. Ignition timing is nice and even through all 6 cylinders. All signs to me post to a boost leak sir! I suggest you smoke test it. An UNLIKELY options would be a faulty turbo. Certainly possible, but not unheard of either. If you smoke test and do not find any leaks... then my eyes would go to the turbo/ WG flap itself maybe excess play inside the housing
11-23-2022, 01:26 PM | #10 | |
Rep 214
Thank you for your kind words sir. I have a question. I am using the oem inlet. Can this be the cause of this? I,ll be grateful if you could clear my confusion. |
11-23-2022, 02:11 PM | #11 |
Rep 668
negative sir, as the turbo inlet is on the suction side of the turbo, not the pressurized side. Boost leaks are on the pressurized side
11-23-2022, 02:30 PM | #12 | |
Rep 214
Lets wait for the smoke test. Will keep you updated. Any other way to check the boost leak? The workshop having the smoke tester is too far. Maybe you could advice something or some video link to help me out. Here is a log with correct oil temp. https://www.bootmod3.net/log?id=637c...729bfbde768ec8 Now suggest Last edited by Zinia; 11-23-2022 at 02:39 PM.. |
11-23-2022, 07:58 PM | #13 | |
Rep 2,595
That said, you can make your own smoke tester with a bike pump, a mason jar, an old sock, a cheap soldering iron, and some baby oil.
2015 BMW 535xi
11-24-2022, 09:06 AM | #14 | |
Rep 214
Yeah i am arranging/making the smoke detector. Hoping for the best |
11-25-2022, 09:04 AM | #17 |
Rep 668
Well that's not good. If it were my car, my next step would be to inspect the wastegate actuator. I'd unhook the EWG and make sure that flap on the turbo is free of obstructions and can seal properly against the housing when in the closed position. I would also pull the turbo inlet pipe so I can inspect the impeller wheel. If that's damaged it will spin but won't compress as well as an undamaged unit (this can be hard to see but I do it by removing the inlet pipe, putting my phone in video record with the flash on then watch your video... or shine a light from the front into the impeller and use a mirror).
11-25-2022, 09:10 AM | #18 | |
Rep 668
11-25-2022, 12:24 PM | #19 | |
Rep 214
Where can i download it ? |
11-25-2022, 04:51 PM | #20 |
Rep 214
Hello everyone
Why does my todays log look different than before or is it just me? 700NM torque 😶 https://www.bootmod3.net/log?id=6381...90c6e22f6d46a3 Can a restricted inlet cause this boost target issue? Last edited by Zinia; 11-25-2022 at 05:09 PM.. |
11-27-2022, 03:21 PM | #21 |
Rep 214
11-27-2022, 03:31 PM | #22 | |
Rep 214
