2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Power supply while using ISTA
      08-10-2023, 10:01 AM   #1
2013F10
Drives: 2013 BMW 535xi
I began learning how to use ISTA on my F10 a few weeks ago and was constantly getting the error that my battery was below 12.55v. I was due for a new one anyway so I bought a BMW battery from the dealership and used my AGM charger/power supply to bring it to full charge. When running ISTA, I also use a Battery Tender power supply . Even with a new battery and this charger hooked up I get the low voltage error. I've tried all of the settings on the charger. I find it odd that I would need to charge this new battery for a few hours before every ISTA run.
My battery reads between 12.1-12.3v, over 14v with the engine running.
Did I waste $135 on this AGM charger/power supply? What are you using? I need to reliably run ISTA as I do most of my own maintenance.
      08-11-2023, 12:59 PM   #2
Hoa
You need a power supply, not a battery charger. BMW recommend at least 50A power supply.
I use a modified server power supply. This link have good instructions how to make one yourself.
https://www.e90post.com/forums/showthread.php?t=1838716
If you don’t want to modify one, you can use something like this that will put out just enough for coding. You will need to get a cheap jumper cable and attach to it.
https://wfcoelectronics.com/product/...erter-charger/
      08-11-2023, 01:54 PM   #3
2013F10
Great, thanks. I found a WF-9855 on eBay for a reasonable price.
