12-24-2023, 08:22 AM | #1 |
Rep 618
Hardwire Radar Detector
Hello, I want to hardwire my Uniden R7 through a mirror tap and can't find a guide for the G87. I know there are guides for other G chassis cars but there are small variations and people have been running into issues where one method may not work on another car (Radar detector won't turn off even after 15+ minutes of the car being locked, causing battery drain and an annoying popup on the dash every time you enter the car).
Has anyone here hardwired their dash cam and know which cable on the mirror (black plug and red plug) to put the taps into? All help is appreciated. Thanks!
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
01-02-2024, 02:00 PM | #2 |
Rep 618
Update: Hardwired my radar in last week but forgot to update the post. I tapped into the front black plug (you don't need to remove it) and the radar turns on with the car and turns off after a couple of minutes after locking it.
1stM384.50 Harlemknight19.00 |
01-02-2024, 05:35 PM | #3 |
Rep 1,872
Have a picture of the front black plug?
01-02-2024, 05:54 PM | #4 |
Rep 618
Here are some pictures
You don’t need to remove the black plug to put the taps in, I almost broke my clip trying to do that (circled broken part in red)
01-02-2024, 09:55 PM | #5 |
Rep 262
I did the same with mine. Thanks for sharing.
Here is YouTube video. The wiring is the same as the M2. |
turnsignalslol274.50 |
01-02-2024, 10:52 PM | #6 | |
Rep 618
01-04-2024, 06:17 PM | #7 |
Rep 1,872
01-04-2024, 06:24 PM | #8 |
Rep 1,872
01-05-2024, 12:05 AM | #9 |
Rep 618
Sorry the pictures were confusing, the photo with the red circle is before the tap, and the two pictures are after. Basically, tap the red wire into the far right port with the red/blue cable and the black/brown wire into the far left port with the black/brown wire
01-22-2024, 08:37 PM | #11 | |
Rep 262
https://www.amazon.com/PlusRoc-Water...9DGDQ48H/?th=1 |
01-22-2024, 10:46 PM | #12 | |
Rep 486
01-24-2024, 10:15 PM | #13 |
Rep 3,016
Drives: A Family Sedan
Thank you for this. I don’t know why I had tapped the connector on the back (which is always on). This is much more convenient. Tested it and it works (it turns off after about 5 minutes, and then it turns on again when you unlock the car, perfect). Appreciate it!
02-21-2024, 08:43 PM | #14 | |
Rep 2
Drives: 2023 BMW M240i
I am asking because I also wanted to tap my R7. I spoke to a local shop that hard wires radars all the time, and he said tapping the mirror is a "terrible idea" because the radar wont receive it's full power. He said he runs a wire through the interior trim and down to the main fuse box. If you are able to find out if your R7 is running at 12v and let me know I'd really appreciate it. |
02-21-2024, 09:44 PM | #15 | |
Rep 3,016
More details on what the shop said or maybe a new shop to earn your business? |
04-06-2024, 12:03 PM | #16 |
Rep 5
OBD power for radar
I found a much simpler solution to power my Valentine radar.
An OBD adaptor: https://www.stickerfab.com/products/...EaAu-hEALw_wcB Powers on and off with ignition. |
