2010 2011 BMW 5 Series Forum F10 F10 Refuses to turn on Ignition |
01-02-2024, 09:53 AM | #1 |
Rep 183
Hi all, was driving last night and stopped to get gas. Next thing I know, it wouldn't go back into pos 2 (when you click the start button)
Here's a link to show you what I mean. Does anyone have any idea? Had to get a tow and as far as I am aware, both my keys work and do get recognized. Since the car won't go into position 2, I can't hookup ISTA and see faults. https://youtube.com/shorts/fmXkScU0R...Fhw0IhJYt-yaDx
Cars give me headaches.
01-02-2024, 04:25 PM | #3 |
Rep 183
Quick update: I believe the ground strap on the transmission went bad (didn't jack up car to check yet) but I added some ground straps on the engine and it starts right up.
01-05-2024, 05:36 AM | #4 |
Rep 1,052
Please let us know what the root cause is when you figure it out! One of the ground straps on my wife’s E90 looks pretty crusty and I’ve thought I should replace it. My F10 is completely covered up so I can’t see these things coming!
01-09-2024, 07:00 PM | #5 | |
Rep 183
If I disconnect the ones I added on the engine, the car will not start or even go into IGN 2 (KL15) Happened to my friends E92 aswell! No crank once that strap goes as that is where the starter gets its ground from
Blue Angel1030.50 StradaRedlands4971.50 |
01-24-2024, 06:04 PM | #6 |
Rep 183
Blue Angel Did my chain and inspected my ground strap. Was connected to my transmission right above the crossmember bracket and it was purple!
Corrosion got so bad that every time I touched it, it crumbled bit by bit. 2012 with 230k miles midwestern car!
01-24-2024, 06:12 PM | #7 |
Rep 1,052
Thanks for the update! We’ve got lots of salt here in Ottawa too, so sounds like something I need to plan ahead for. Thanks for the tip!!!
