02-12-2024, 08:08 PM | #1 |
Rep 139
Someone stole my mirror
So I was at work today and someone stole my passages side view mirror (just the glass). The a-hole snipped the wires through so I think I am going to have to change the control module or look for a salvaged mirror.
There are 4 wires bundled together which were snipped. I assume the wires were for the heat and the auto tilt. Anyone have any experience changing a control module? I’m looking on eBay but the ones that I found seem to have more wires (camera perhaps). Thanks in advance for any input. |
02-12-2024, 11:04 PM | #2 |
Rep 844
Sorry about the situation...but it's not as bad as you think.
1. The 4 wires are for, 2 wires for heating, 2 wires for auto dim (not dip) 2. Auto dip (reverse curb view) is managed by the mirror motor The mirror is easy to repair with a connector repair kit sold on Amazon and eBay ($9 each connector) The mirror (US version with the black plastic trim around the edge of the mirror), is pretty expensive used, ~$200. You have a choice to buy the EU version that provides a larger reflective surface, and the outer edge of the mirror provides better visibility of your blind spot for ~$100. |
culto50.50 StradaRedlands4974.50 |
02-13-2024, 05:17 AM | #3 |
Rep 7,539
Sorry to hear this. But to anyone that has folding mirrors…this is one example where if you fold them inward when parked in public…it can be a slight deterrent for this type of pilfering. When the mirrors are folded inward, it is difficult to try to steal the mirror glass.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
culto50.50 |
02-13-2024, 06:32 AM | #4 | |
Rep 139
02-13-2024, 06:37 AM | #5 | |
Rep 139
Thanks! Where can I buy the EU version? |
02-13-2024, 03:16 PM | #6 |
Rep 7,539
The best way to find a Euro wide angle (aspherical) mirror is to pull the mirrors up in one of the online part database sites like realoem.com or bimmercat.com but select for a Euro market model that is like yours.
Then pull up the mirror diagrams and scroll down to the part nbr for the wide angle mirrors that have the same options you have. Once you have the correct 11 digit BMW part nbr for the wide angle mirror that fits your option codes etc...the simply google BMW xx xx x xxx xxx {where x= the actual part nbr}. You'll usually find sellers on eBay or Amazon.com and some of the aftermarket vendors that sell oe parts. I've purchased these mirrors for every BMW I've owned since learning about them. The last few times...I've gotten them from vendors in the Baltic States (Lithuania/Latvia/Estonia) and once from a seller in Germany. Back in the 90s you could order them from the Euro side of the BMW parts database from your local BMW dealer's parts department. Examples of the wide angle mirror: Top mirror is the standard DS plain mirror glass Bottom mirror is the wide angle DS mirror glass (note that more parking spaces can be seen in the Wide Angle Mirror.
02-13-2024, 04:06 PM | #7 |
Rep 139
[QUOTE=Qsilver7;30900893]The best way to find a Euro wide angle (aspherical) mirror is to pull the mirrors up in one of the online part database sites like realoem.com or bimmercat.com but select for a Euro market model that is like yours.
Then pull up the mirror diagrams and scroll down to the part nbr for the wide angle mirrors that have the same options you have. Once you have the correct 11 digit BMW part nbr for the wide angle mirror that fits your option codes etc...the simply google BMW xx xx x xxx xxx {where x= the actual part nbr}. You'll usually find sellers on eBay or Amazon.com and some of the aftermarket vendors that sell oe parts. I've purchased these mirrors for every BMW I've owned since learning about them. The last few times...I've gotten them from vendors in the Baltic States (Lithuania/Latvia/Estonia) and once from a seller in Germany. Back in the 90s you could order them from the Euro side of the BMW parts database from your local BMW dealer's parts department. Examples of the wide angle mirror: Top mirror is the standard DS plain mirror glass Bottom mirror is the wide angle DS mirror glass (note that more parking spaces can be seen in the Wide Angle Mirror. Thank you! In the meantime I bought a cheap replacement mirror from Amazon which just arrived and I am filling a police report tomorrow. |
02-13-2024, 09:53 PM | #9 | |
Rep 844
1. Pin 1: Brown wire 2. Pin 2: Red wire 3. Pin 3: Purple wire 4. Pin 4: Black wire |
02-14-2024, 09:21 AM | #10 | |
Rep 139
03-03-2024, 02:07 PM | #11 |
Rep 139
Update: it was cheaper to buy a whole mirror assembly with the glass from a salvage yard than to just buy the glass itself. Swapped the mirror assembly and the mirror cap today and everything is working great.
