02-16-2024, 06:56 PM | #1 |
V.I.P.
40
Rep 251
Drives: F10 535i 2011, F10 550i 2015
Haunting O2 Sensor Code
Hello everyone,
I've been experiencing rather unusual downstream O2 Sensor codes that won't go away. After countless hours of diagnosing and spending quite a bit of money i feel defeated and have finally decided to ask for some support from the community! Just two quick notes: new O2 sensors, same codes, local shop verified O2 sensors were fine. Im aware of the Service Bulletin addressing some code fixes, current I-Level is below and newer than bulletin. I'm on BM3 currently, however, codes persist on stock flash. Any help would be much appreciated. Below is a list of parts changed and the codes im experiencing. Car drives excellent and just passed smog (I was able to catch it while the CEL was off). All monitors complete. Replaced the downstream O2 sensors (upstream are new too) Replaced both intake ducts Replaced both MAF sensors I Level is : F010-19-11-520 ((2019) newer than than the bulletin) Codes: 12AB04: Lambdasonde2 Bank1, electrical: Line break 12AC04: Lambdasonde2 Bank2, electrical: Line break 12B701: Heating Lambasonde2 bank1, function: internal resistance too high 12B801: Heating Lambasonde2 bank2, function: internal resistance too high 2015 N63TU 550i BM3 STG1, XHP STG1, N63INTAKE OIL COOLER VALVE I appreciate your help. Thanks
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC Last edited by obiltagi3; 02-16-2024 at 07:04 PM.. |
02-16-2024, 08:29 PM | #2 |
Rep 441
Drives: 2016 F10 BMW 535i M Sport
Check those O2 Sensor connections very thoroughly. Something possibly with your Catted DP, however My educated guess its the connections itself.
02-17-2024, 03:56 PM | #3 | |
V.I.P.
40
Rep 251
Tip: The O2 sensors im using are the OE Bosch 15167, not original BMW. I don't see that being an issue, just wanted to share. Thanks for the input!
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC |
ChiltiCoatl891779.50 |
02-17-2024, 05:56 PM | #4 |
Rep 441
Only thing else I Could think of of they are installed in the wrong banks, I am not exactly familiar and stand corrected if they're the same PNs (Or not) as I am still learning BMWs, however Back to OEM Dp you shouldn't be throwing codes like that. Good post!
obiltagi339.50 |
02-18-2024, 02:11 AM | #5 | |
V.I.P.
40
Rep 251
Thanks for reaching out and I appreciate the feedback! Anyone else have some thoughts to share? Thanks!
02-29-2024, 01:28 AM | #6 |
V.I.P.
40
Rep 251
Bump! Willing to give a small token of appreciation to anyone who provides me a solution that fixes this!
02-29-2024, 08:21 PM | #8 |
Rep 441
Have you tried swapping the O2 sensors for new ones to make sure they are not the issue? Or one at a time? Always good to try that. For peace of mind?
obiltagi339.50 |
03-01-2024, 07:03 PM | #9 |
V.I.P.
40
Rep 251
Yes I have just changed them again.
The codes continue, however, I think I have finally found the solution. Will keep updated.
03-01-2024, 07:29 PM | #10 |
Rep 441
03-02-2024, 02:48 PM | #11 |
V.I.P.
40
Rep 251
So, I decided to diagnose many of the AFR components. (You can see above the parts I changed)
Realized it’s been 35K miles on spark plugs, tuned and no misfires. Anywho, decided it was time to change plugs and coils. (I prefer to change these before a CEL, as I know the interval is coming up soon). Spark plugs looked pretty fouled. I’ve changed plugs on previous F10 over 10 years so I know how they typically look. For some reason, these plugs looked like they had some kind of buildup. I’ll post a pic for anyone who wants to chime in on what that buildup might be? Anywho, I have not received any O2 downstream codes since the change of plugs + coils. All monitors are up (nothing changed here). No CEL. 120 miles in, will check back in a couple more hundred miles but all is looking good now. Looks like I needed spark plugs for a whole year despite car running fine and no misfires I’ve never seen spark plugs cause O2 downstream sensors issues, can anyone explain this? I hope this helps someone in the future! Thanks
03-02-2024, 02:52 PM | #12 |
V.I.P.
40
Rep 251
Here’s a pic of the plugs; as you can see, many of them just look burnt or like a typical used spark plug.
However, 4 plugs, that were in cylinders 3/4 and 7/8 had some kind of rusty looking buildup.
03-02-2024, 07:28 PM | #13 |
Rep 441
I am looking into what may cause the discoloration, other than normal wear, Rich/lean differences in buildup.
03-02-2024, 07:34 PM | #14 |
Rep 441
Running lean on your spark plugs, Grayish color which means plenty of air or more air to fuel, of course, and you are in OC in California? or?
03-02-2024, 07:52 PM | #15 |
V.I.P.
40
Rep 251
Interesting, I was running the front mount intake for a while. It looks and sounds good, but went back stock when I saw how much dust was coming through the PG air filter into piping
03-03-2024, 09:07 PM | #16 |
Rep 441
To me the corrosion or rust looking material, my educated guess, could be from trapped moisture before the seal of the electrode of the spark plug, from condensation. Doesn't look harmful as the seal did its job. Evidence of the car being in humid conditions. Has your car ever sat for long period of time without starting? Or is it parked outside?
03-04-2024, 02:20 PM | #17 |
V.I.P.
40
Rep 251
200 miles in no CEL
Car is always parked outside, it’s my daily driver ! The vehicle is home to California Appreciate your help !
03-07-2024, 08:44 PM | #19 |
V.I.P.
40
Rep 251
Sure! Just pm me if you’re in town
