2010 2011 BMW 5 Series Forum F10 F10 LCI issues need a little help |
03-20-2024, 05:48 PM | #1 |
Rep 3
Hey guys, I just ran into some issues with my F10 535i. I looked all the codes up no one really have an answer and if so they're not fixing my issue. I turned my car on the other day and my fan came on at the same time, then I had no power on my Climate/ Radio. My reverse camera also went out, then driver and passenger restraint malfunction. I thought I needed a new battery, got one replaced and coded it issue still remains. I try and push it to see if it would over heat it stays at normal temperature while the fan is on jet speed. I used BimmerLink for the codes and I keep getting : C90D60 cleaned the sensor it doesn't show up. C91402 - water valve timeout C91404 - status climate timeout CDB804 - air conditioner request missing Also a bunch of other codes which I assume have to to do with these not working like my restraint system and my power seats sometimes do not work as well as power trunk. All my fuses are ok 2 in the trunk were not working I replaced them problem still remain they were fuses 203 and 204 in the trunk.
03-21-2024, 08:22 AM | #4 |
Rep 265
Gremlins appear everywhere when you have an electrical drain going on, often caused by the Comfort access doors handles. I would suggest you check them out. Google it.
ChiltiCoatl891775.00 |
