2010 2011 BMW 5 Series Forum F10 Error 132408 Intake cam not locking position at startup |
03-26-2024, 07:04 PM | #1 |
Rep 741
I posted this in the 6 Series also: 2013 N63TU V8 Twin Turbo
So, I got a check engine light on. Code 132408 VANOS solenoid valve, exhaust: Intake camshaft not in locking position at start up. Mileage: 40,000 Only drive 5,000 miles/year Car seems to run fine, no rattle at start up, normal startup, smooth idle, smooth running, haven't asked for a lot of turbo power so don't know what would happen. But I rarely ask for a lot of power as this is my laid back driver. My C8 is for spiritized fun. So: Is this something I should be concerned about or can I just live with it? And wait for a more serious code before doing anything. If it's just a bad solenoid valve, I don't think it's going to hurt anything in the engine. |
04-17-2024, 11:43 PM | #2 |
Rep 741
Ended up buying two standard equipment BMW parts for $450 two weeks ago and anticipated having a local independent BMW shop install them at sometime in the near future. Today the check engine light came went out. Will be returning the parts.
04-18-2024, 01:43 PM | #3 |
Rep 5,409
IMHO, the code will return. I would keep the parts. Or maybe the VANOS solenoids just need a good cleaning.
04-18-2024, 02:18 PM | #4 |
Rep 741
You're probably right but if it just keeps coming and going, I'm going to consider it not that serious. And for the V8, getting to those solenoids is not that easy and once there I think it makes sense to just replace them rather than try to clean them. And if I do decide to replace them at some point, I'm going to buy the cheaper Pierburg units at $125 each since that's who makes the part for BMW.
04-18-2024, 03:06 PM | #5 | |
Rep 506
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
04-18-2024, 03:36 PM | #6 |
Rep 741
No it didn't.
To me the car ran normally with only the yellow engine light on. It threw two codes the second one being 132608 which indicates "VANOS solenoid valve exhaust 2: Intake cam not in locking position at start up". I read that to mean the problem is with the exhaust VANOS solenoid in bank #2 that is the problem. Apparently, an intermittent problem. |
05-20-2024, 11:59 AM | #8 |
Rep 741
So, the engine light went out after a couple hundred miles and maybe 6 starts. Returned the two solenoids for a refund ($450). After another couple hundred miles the engine light came back on. Same fault 132608.
Because this car is my luxury cruiser that I drive it rather mildly and relaxed since I have my Corvette for spirited driving. Started thinking maybe that's why the vanos system is not returning to the start position because I'm not "exercising" the solenoid through its full travel and it was hanging up. I really don't know if that it's true or not. But for the next 3 or 4 times out, I did some spirited accelerations at least once each time out. And the car was due for its annual inspection and that's when I change the oil & filter. After the next hundred miles or so the engine light goes out again. So I've been making it a point to do a moderately fast acceleration each time I take the car out. So far the engine light has not come back on. During this entire time the car always ran smooth, no noises and no smoke. Maybe someone with more knowledge about the vanos system could pipe in about whether my reasoning makes any sense. |
