04-21-2024, 12:09 AM | #1 |
Rep 2
Drives: 2013 BMW 535i stg2+
maybe vacuum leak
2013 535i downpipe, stg2+, charge pipe, fmic
had a bad o2 sensor then got it fixed. it was running good. cel came on and i got similar symptoms to the bad o2 sensor. no stalling but whenever i brake and come to a stop the car rumbles and sounds like it is about to stall but it doesn’t. if i’m parked it will occasionally rumble (i think misfire) but it doesn’t stall. driving is fine everything is just when rpm’s are low. the codes i attached are the ones i got when i ran them initially. i checked my maf and vacuum lines and cleared the codes. they went away but came back shortly later this time just with a fuel mixture too lean code. cel is on now and it is just lean code when i scan it. any ideas? |
04-21-2024, 01:09 PM | #2 |
Rep 670
I suggest a smoke test as a starting point.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
jdelpup11.50 poverty.f1078.00 |
04-21-2024, 03:32 PM | #3 |
DIY Mechanic
78
Rep 131
Drives: 2012 BMW 535i xDrive
How much rpms is it dipping?
You can live in a car but you can’t race a house.
04-21-2024, 03:38 PM | #4 |
Rep 2
it drops to around 500 probably when i brake and it rumbles and misfires for a second but then goes back to normal idle
