2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum New owner - are these codes bad?
      07-17-2024, 01:01 PM   #1
moreensby
Drives: F11 530d | E92 325i
Question New owner - are these codes bad?
Hello everyone,
Recently purchased a 530d F11 2014 with N57 engine.
Currently 1 owner before me and has done 89k miles.
I’ve taken it to my local garage (not particularly BMW focussed, but I trust them) for a service and a general checkover. They did an oil change and ran the codes but they were concerned with the potential costs of getting these issues fixed, before I commit to it.
I decided to run the codes on ISTA myself (had it from my previous E92) to see what I would get. So here it is:
  • 24BF00 - Injector, cylinder 2, zero-quantity adaption: activation duration correction too high
  • 254A00 - Hot film air mass meter: Air mass too low (signal frequency too low)
  • 275000 - Misfire detection cylinder 2: Number of detected misfires too high
  • 27F000 - Air mass system, charge air hose: Leak detected
  • 290900 - Air mass system: Measure air mass too high
  • 2A6800 - Smooth-running regulator, cylinder 1: Correction quantity outside permitted range
  • 2A6C00 - Operational smoothness regulator, cylinder 2: Correction quantity outside permitted range
  • 2A6D00 - Smooth-running regulator, cylinder 4: Correction quantity outside permitted range
  • 9308B0 - Identification transmitter: undervoltage, battery
Worth noting:
  • Garage said they saw what looked like diesel in the turbo and said they think there’s cylinder wash. They also mentioned that they think there’s loss of compression, but I would expect to see a fault for that?
  • Car runs rough, especially on startup, reduces once up to temp
  • Sometimes produces a lot of grey/dark white smoke, but it’s totally random. Sometimes it won’t happen for a week and then the next week it’s constant. It can get quite bad to the point people notice it on the street.
  • Often get quite a bad diesel smell in the outside of the car, have noticed sometimes there's also smoke from the engine bay
Presumptions:
  • Looks like I definitely will need a new injector
  • Issue with the MAF?
Questions:
  • Has anyone had similar looking issues? Any
  • Is it advisable to just replace 1 injector, or all 6?
  • Are the other cylinder warnings related to imbalance because of injector 2 or because there’s issues there also?
  • What would be the things I should get fixed/looked at to get these issues resolved
      07-17-2024, 06:03 PM   #2
Hoa
There are many issues but to tackle it properly, you first need a new battery and MAF sensor. Those two are bad. Then you can see if the misfire is due to a bad MAF or something else. Bad battery also cause a lot of issues on these cars. The shop should have done a compression test for you while they have it.
Injector, spark plug, ignition coils and high pressure fuel pump can also can contribute to misfire but they can be rulled out once you have good working MAF and battery. You don’t want to replace a bunch of parts and still didn’t fix the problem. Also, injectors requires programming. If previous owner replaced it and didn’t program, it may not run smooth as well.
      07-22-2024, 01:06 PM   #3
moreensby
Appreciate your help Hoa.
So the battery code 9308B0 actually relates to the battery of the key fob, so I'll ignore that one for now.
I took the MAP sensor out to inspect it, there's not much build up, but I could see that the plastic looks like it has slightly melted from heat, so I've ordered a new one.
In terms of the MAF sensor, I'm going to wait to see what improvements that a new MAP sensor will make, as mentioned above, before buying that as I'd rather avoid that if I don't need it.
I inspected a hose on the front left of the engine that went down towards the subframe that I presume was the crankcase breather hose, but I can't find a diagram of where that is located on an N57, does anyone know? This hose had what looked like a leak on the lower connector, but it was difficult to see. May this be the boost leak?
      07-23-2024, 04:32 PM   #4
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
I'm not familiar with the N57 but try www.realoem.com to find diagram/part # for the hose you're talking about.
      05-14-2025, 04:43 PM   #5
Krizzle
Drives: BMW F11 530D
Moreensby, Hi there I own a BMW F11 530D 2014 LCI N57N Engine with 90k miles on the clock and I am currently also going through same issues as you’ve listed, first I’ve been told by several people to get my injectors done which I have but the issue is still there.
Starting the car up in the morning, White/Gray smoke with the car shaking/vibrating until it comes to temperature then smoke goes away.. but the shaking/vibrating still remains..
Faults that are currently popping up are as follows
290900 - Air mass system: Measured air mass too high
2BA400 - Charging pressure actuator: closed too loosely
Any suggestions of what I should be doing first since injectors weren’t the issues after all.. anything would be much appreciated.
