2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Rear Suspension Creek
      10-11-2024, 09:30 AM   #1
f10Ben
f10Ben's Avatar
Drives: F10
2011 BMW 535XI  [8.00]
Hi all,
I have a 2011 535xdrive. My back left suspension makes a loud creeking and rocking noise after going over speed bumps or anything at low speeds and I don’t hear this on the highway. I believe this will require new shock strut assembly. I linked one to this.
Does anyone know:
1. That is workable option to fix my issue?
Shock strut Assembly
2. How long this job would take or a video that they used?
Thank you so much!
      10-11-2024, 11:15 AM   #2
Cvx5832
Drives: ‘15 535i M-Sport
I found the job to be easy enough. The main thing to be aware of is that the suspension arm will swing UP as this is its normal position. You'll need to find something to hold that down for you to slide the strut assembly in. Some used breaker bars, some used a second person to stand on the rotor, I used a 3300lb ratcheting strap. The force to hold down those arms is not trivial.
For those going the full route, this type of compressor is perfect for the task.
      10-11-2024, 07:38 PM   #3
Conserve
Drives: 1976 BMW 2002 & 2015 BMW535i
Take the wheel off to see what is going on. Probably broken coil spring?
I personally stay away from such assemblies. Check FCP Euro. You could buy OE parts for very reasonable price.
https://www.google.com/search?q=how+...hrome&ie=UTF-8
      10-12-2024, 08:59 AM   #4
f10Ben
f10Ben's Avatar
Drives: F10
Hey so I just took the wheel off and realized this strut looks nothing like any of the videos. It seems to be an EDC one. Does anyone have experience with how to remove this or what I should do next? I assume I can’t replace it with a normal one. And I believe the issue is just the spring in the last photo. Thanks again 😭
      10-12-2024, 07:23 PM   #5
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
Looks like that's definitely the problem. There are still some whys to be answered though.
As for removal, I think you just unplug the wiring... trace it to a small junction box and there should be a plug. Guessing on that though as I've never done it.
      11-18-2024, 09:36 PM   #6
TorqueAndBavaria
Semi-Feral Mechanic
TorqueAndBavaria's Avatar
Drives: 2012 BMW 535i xDrive
That spring is toast. Get a new spring, top and bottom isolators and a new top hat bushing.
You can live in a car but you can’t race a house.
      11-20-2024, 06:49 PM   #7
Conserve
+1^
That is your suspension problem. That coil spring is broken and shock/ strut body is very rusty
