2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) 2021 BMW 330i – Engine Mount Vibration Issue (Video Included)
      06-09-2025, 11:45 AM   #1
serhatrt
Drives: Bmw 330i
Hi everyone,
I’m experiencing a persistent vibration and resonance issue with my 2021 BMW 330i (B46 engine, RWD), especially noticeable at idle and under light throttle. The car has only 30,000 miles on it. There are no warning lights or error codes, and the OEM spark plugs were recently replaced by a certified BMW technician.
Today, I had the engine mounts, transmission mount, and exhaust system inspected by a BMW service technician. All mounting points were physically tested using a pry bar while I was present. I recorded several short videos during the inspection.
Although I observed clear movement in the engine mounts during the pry bar test, the technician stated that everything looked “normal” and made no mention of the vibration in the final report. However, the vibration is clearly felt both in the engine bay and inside the cabin.
So I wanted to ask:
Has anyone experienced a similar vibration issue?
Is this level of movement during a pry bar test normal for OEM mounts?
LINK: https://drive.google.com/file/d/1Cl-...LQL5/view?t=42
Could this indicate early wear, or are the mounts just this soft from the factory?
I’m happy to share the videos with anyone interested. I’d really appreciate any insight or similar experiences.
Thanks in advance
      09-11-2025, 04:18 AM   #2
kylegy
kylegy's Avatar
Drives: 2024 BMW M340i xdrive
How did you make out? Both mounts on my g20 330i are leaking and i’m at 40k miles. Dealership quoted me $2,300 for both mounta to be replaced.
      09-17-2025, 08:19 AM   #3
John in VA
Drives: 2015 228i M Sport
Try posting in the chassis/suspension section vs. cosmetics/detailing. Good luck!
https://www.2addicts.com/forums/forumdisplay.php?f=522
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      09-27-2025, 07:53 PM   #4
quakerroatmeal
Drives: 2021 BMW 330i
You can buy both mount on fcpeuro for around 375$. I'd take it to a independent shop to quote you on labor to install.
kylegy3.00
      10-31-2025, 01:12 AM   #5
limAcki
Drives: BMW F30 316d
I’ve just replaced the engine and transmission mounts on my F30 (B47) 2017 with 178,000 km. After months of dealing with vibrations, increased noise, gearbox shaking, and jerking when taking off, I finally replaced them – the difference is incredible, even though the first mechanic suggested the DMF was to blame. Luckily, I didn’t believe that and had Lemförder mounts installed by another local mechanic for about $350. The old mounts seemed fine at first glance, but it was noticeable that they had “sagged.”
      01-13-2026, 09:56 AM   #6
Monkey5
Drives: '19 330 m-sport, '23 x3 msport
I was experiencing vibration at idle in drive, the motor mounts seemed to be a bit collapsed, the bottom of the mount was sagging. I replaced both and the vibration did not completely go away, in fact it seemed worse at times. Sometimes it's totally smooth, can't tell it running. other times the steering wheel shakes..... Anybody have an idea what's going on?
