| 09-15-2025, 04:50 AM | #1 |
Rep 1
Steering pump replacement
Hello,
Does anybody have a small DYI or video on how to replace the steering pump on a F07 530Dx drive. My steering pump makes a squeeling noise when taking turns, and a flush of the oil didn't really help to fix it. Thanks |
| 02-18-2026, 12:03 PM | #2 |
Rep 6
I did it, you can do it from the top. Remove alternator and loosen airco pump(then put it on the side, its connected with flexible hoses) some nuts and bolts you need to reach from the driver side wheel, so remove the wheel and the liner.
Then you will have access to the steering pump. Make sure you empty the power steering fluid(chf11s) and fill it up again when you are done. |
| Bookmarks |
