2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Waxing After Ceramic Coating?
      02-22-2026, 05:15 PM   #1
JerseyM3
Drives: 2025 M3 Comp xDrive
Does it make sense to add a coat of wax when the paint has a ceramic coating, or another coat of ceramic is the way to go?
      02-22-2026, 06:21 PM   #2
Venti26M2CS
Venti26M2CS's Avatar
356
Drives: 2026 M2 CS
2024 Lexus RX350  [0.00]
2026 M2 CS  [10.00]
Sure. What’s your reason tho? Protection or looks?
For looks, a good coat of carnuba can’t be beat for that dripping wet gloss. And absolutely no problem to do that on top of a ceramic coating.
For protection, wax won’t offer protection for very long. So if that’s your goal, another coat of ceramic is the way to go.
Either way, make sure your maintenance washes are with a ph neutral soap like carpro reset, or there’s a ton of other options out there.
FrankL176.50
      02-22-2026, 08:37 PM   #3
afadeev
afadeev's Avatar
4393
Drives: F80 M3
It is possible, but not necessary.
Whichever layer of "protection" is shortest lasting (wax), will disintegrate first. So layering shorter lasting wax on top of longer lasting ceramic coating has no downsides, other than the time and effort you will be invested. Some waxes might provide a "deeper" shine to the paint, but we are splitting hairs here.
All this assumes that you will diligently clean the ceramic coating first, otherwise, you will be scratching everything my moving dirt around while applying wax.
You could do that, but it's unlikely to be a good idea.
1). If the old coating is failing, you want to remove/strip it before applying new coating. Else, the old one will continue failing and will undermine the bonding between the paint and the new coating.
2). If the old coating is NOT failing, it will still fail sooner than the new in the future. Revert back to scenario #1 above.
If you just want to "maintain" it after washing, there is a ton of inexpensive ceramic ceramic infused spray-on products out there (I will link a few below). You can just mist those on the paint after washing, and it will make the old coating look and bead water like new. For a few months.
https://adamspolishes.com/products/a...b27d9f5e&_ss=r
https://adamspolishes.com/products/g...b27d9f5e&_ss=r
https://www.griotsgarage.com/ceramic-3-in-1-wax/
HTH,
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's
      02-23-2026, 08:24 AM   #4
JerseyM3
Thanks for the replies. I think since the work to do a wax coat is close to another coat of ceramic, i may lean on that instead. Can you clay or decontaminate over a ceramic coat or will it damage it?
      02-23-2026, 08:31 AM   #5
Phillies8008
Drives: BMWs, duh
2026 BMW Z4 M40i  [9.50]
2024 BMW i4 e40  [9.50]
2006 BMW Z4M  [10.00]
If you clay it you're going to take the coating off. Really, all it should take is a good wash.
FrankL176.50
      02-23-2026, 06:59 PM   #6
Tobster3
Tobster3's Avatar
939
Drives: X5 M60i
I would not put a coat of Wax on. You can add to the Ceramic Coating by using something like CarPro Reload which is a Sio2 quartz spray.
https://www.carpro-us.com/protection...As0isqc5uNqQuX
      02-24-2026, 04:28 AM   #7
avi66
avi66's Avatar
Drives: X3 M40d LCI
Just use a good value spray coating on top, such as Turtle wax Hybrid Ceramic spray coating, it’s relatively cheap, easy to apply, long lasting and effective under test.
FrankL176.50
Westside Guy10262.00
      02-24-2026, 10:20 AM   #8
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
just toss on an sio2 or graphene based detailing spray when you dry the car after a wash
      02-24-2026, 11:30 AM   #9
JerseyM3
I like chemical guys products and I do use their spray on ceramic coats. Just was wondering if wax leaves a thicker level of chemical protection than a spray. Its gonna be bird sh!t season soon.
      02-24-2026, 12:01 PM   #10
Phillies8008
Drives: BMWs, duh
Wax generally doesn't offer much protection but is rather for appearance's sake. Ceramic will fill that role much better.
FrankL176.50
      02-24-2026, 12:16 PM   #11
avi66
avi66's Avatar
Drives: X3 M40d LCI
With bird crap the car paint damage process is “mechanical”, in that it’s the cycle of heating and cooling of the deposit that cause the surface of the paint to deform from smooth (etching). It will even do this through a proper ceramic coating over time, as it’s not a “chemical” attack.
The only real solution is get it off the paint as quickly as possible, especially in hot climates.
There is/was a product from Autoglym in the UK called Reflow that uses heat to reduce/remove paint surface etching caused by bird crap.
      02-24-2026, 08:05 PM   #12
JerseyM3
Yeah i saw that. The reflow application scares the crap out of me. It actually heats up the paint to almost a liquid state. Just so many things could go wrong 😆 at least for me!
      03-13-2026, 04:18 PM   #13
chris719
Drives: '08 M Roadster
It does very slightly, but the problem is that most waxes have strong solvents that could degrade the coating eventually. Some even have abrasives.
People will tell you there is no problem topping a coating with wax but I have tried it on an acrylic test mirror with ADS Quartz and CarPro DLight with a handful of waxes and it's hard to get them back to original performance after a few applications of the wax for whatever reason, even with strong cleaning and water spot remover.
      03-13-2026, 08:01 PM   #14
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Like putting McDonald's bbq sauce packets on your $100 ribeye steak
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      03-14-2026, 08:38 AM   #15
Westside Guy
Westside Guy's Avatar
10262
Drives: 22 Z4 M40i, 21 228i Retired
I would recommend a second coat of ceramic and if you are doing this in a shop that uses one of these, they are top of the line products.
      03-27-2026, 11:11 AM   #16
RussV
Drives: 2025 BMW M340i
I put Collinite 845 over my ceramic coated Vegas Red. Made the color pop.
      03-27-2026, 05:42 PM   #17
chris719
You have to be careful, some waxes have mild abrasives and even if not, some have solvents that will eventually degrade the coating's performance.
      03-28-2026, 07:57 AM   #18
rmedina
Drives: 2023 M340i
You'll lose the hydrophobic properties of the ceramic coating. Top it with a ceramic quick detailer and you'll be good to go.
      03-30-2026, 06:44 AM   #19
Mizuno
Drives: 2021 540i M-Sport RWD
no. wax will build up and clog the ceramic coating, ruining the whole reason for it. use a ceramic detailing spray every now and then to keep the coating fresh. stay away from any traditional waxes
      04-15-2026, 07:15 AM   #20
jmangee
Drives: bmw I4
What interior cleaning products are you guys using? I dont like the shinny look, like more the matte effect but some of the smells are too synthetic.
      04-15-2026, 07:34 AM   #21
fiveightandten
fiveightandten's Avatar
207
Drives: F22 M235, E36 M3, E30, X3 M40i
You can open up a thread to discuss this and get answers relevant to your question.
