2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW F10 520D N47 Drive Train Issue - 297800 and 244D00
      03-07-2026, 09:28 AM   #1
anonymousvoid404
Drives: BMW F10
BMW 520D 2011 just started with Drive Train issue, flashes up and then goes away.
I have have used Bimmerlink and its showing codes 297800 Boost Pressure Actuator & 244D00 Boost Pressure Control. The codes seem to be confusing and could relate to DPF pressure issue
Is this the Turbo Solenoid Value or PDF issue ? and if so what is the location?
What I have noticed is that in Bimmerlink the Differential pressure across DPF at with only the ignition on is Negative 0.01, and when under load only rises slightly.
