2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Oil Change Mess
      03-15-2026, 07:02 AM   #1
spazzyfry123
spazzyfry123's Avatar
Drives: Here and There
Oil Change Mess
Took one of the vehicles in for its very first oil change (brand new). Heard them drop the bottom pan clear on the ground with a big racket and laughing about it. Heard some arguing back and forth on the quantity of oil. Just an overall disaster of an oil change.
Drive it straight home and park it for a couple hours to head out into the property for a bit. Come back and find about a dozen oil stains on my brand new concrete pad. Look underneath and find effectively the entire underside of the front of the vehicle covered in oil. Dripping from skid plates, control arms look like they’ve been dipped. Skid plates are pooled up with puddles. Looks like a quart’s worth was just sprayed on the underside.
What’s the best way to get the underside back to looking like it did just hours prior? Which was brand new with hardly any dust. I plan to have my detailer do it, but would be interested from the larger group what’s typically done in these situations so I’ve got a point of reference to decide. Thinking I shouldn’t drive it until it’s cleaned up to avoid more spray down the underside.
Bonus points if anyone has direction for the concrete as well.
      03-15-2026, 09:07 AM   #2
John in VA
Drives: 2015 228i M Sport
Wherever you took it for the oil change should be on the hook for the clean-up - I hope you let the service manager or general manager know about the mess. I wouldn't let them touch it again but have them reimburse you for the detailer.
Maybe your concrete guy has a solution for that clean-up.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
dcstep1723.50
      03-15-2026, 09:36 AM   #3
RockCrusher
Drives: BMW 2024 M8 Competition Coupe
Clean up is the least of your worries. I'd be very concerned about the oil level. And even after topping up the oil level I'd worry about the engine losing too much oil on the way back to the shop.
For smaller clean ups brake cleaner from an aerosol can works well. The brake cleaner dissolves oil but leaves no residue. I put down a good multi sheet layer of newspaper to catch/hold the cleaner run off.
For clean up of a huge mess I used Gunk in an aerosol can (cans) followed by a hosing down with water.
Professional techs that I have known like Simple Green. I have no experience using Simple Green. It has been decades since I had a mess that required Gunk and the smaller messes I manage to create are small enough that brake cleaner suffices.
For oil stains on concrete brake cleaner again and lots of paper towels.
Finish with a good coating of oil dry -- the kitty litter like stuff -- and work it in to the surface of the concrete.
There may be off the shelf concrete liquid cleaners but I never needed any as the few times I made a mess on the concrete I had brake cleaner cans handy.
      03-15-2026, 10:25 AM   #4
E36 wire harness
It could always be worse
E36 wire harness's Avatar
751
Drives: E53 X5 6mt, F30 340ix 6mt, E36
I've seen this stuff called "pour and restore", it looks like it's really good but I've never been able to find it on a shelf. I've had half decent results with the zep purple and the deck scrubbing brush / power washer.
      03-15-2026, 10:37 AM   #5
dcstep
Drives: '22 M4 Comp X-dr 'Vert
I don't know the 8-series, but you probably can't check the oil level without running the engine, which wouldn't be safe with all the leakage. I'd talk to the GM, have him send a flatbed and ream them good on both the BMW review and Yelp and Google. Never go back to that dealer.
      03-15-2026, 12:50 PM   #6
Emm2Upstart
Drives: G87 M2
As someone mentioned, an aerosol can of brake cleaner dissolves oil on contact. Look closely around the oil cap. I wouldn't be surprised if they left a mess there too, and then it dripped down to everything, to the undertray areas.
Edit: Use the brake cleaner under the car. I wouldn't personally use it much in the engine bay because all of the plastics -- unnecessarily harsh cleaner for that area.
BMW service made a huge mess at my last oil change -- it even sprayed on my windshield as I was driving home. They offered to pay for a detailer but that was more of a hassle for me. I carefully sprayed down the engine bay with a solution of dish soap and then gently rinsed with water. Took about 5 minutes.
I don't know how they could so badly mess up an oil change. Good luck!
FrankL176.50
      03-15-2026, 02:30 PM   #7
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
Try muriatic acid (hydrochloric acid (HCl)). I would normally use it to clean water spots from a boat, but have also used it on oil stains on a garage floor. Most times it is effective.
If you give it a try, wear thick rubber gloves and real eye protection. Stuff can be nasty.
      03-15-2026, 03:02 PM   #8
FrankL
Drives: 2018 BMW X5, 2014 320i
Where did you go? A BMW dealership or Jiffy Lube? What a clown show.
      03-15-2026, 03:30 PM   #9
Code Monkey
Drives: M3
Please name the shop/dealer.
      03-15-2026, 04:31 PM   #10
fiveightandten
fiveightandten's Avatar
207
Drives: F22 M235, E36 M3, E30, X3 M40i
The whole underside of the car needs to be cleaned. A good detailer with a lift will need to remove all the under panels and have at it with a degreaser and a pressure washer. Either the dealer should pay for this, or provide the service themselves. The fabric under panels may need to be replaced, depending on how much oil they’ve soaked up.
But as mentioned above, the bigger concern is whether or not the engine was oil starved or otherwise compromised.
I have an asphalt driveway, not concrete. But can vouch for regular old laundry detergent being effective at removing fairly fresh oil stains. Though there may be better methods for a new concrete surface.
      03-15-2026, 07:43 PM   #11
dcstep
OP, what the hell is going on? Don't start it. Have another dealer come pick it up with a flatbed and fix everything.
philth882.00
      03-15-2026, 08:15 PM   #12
philth
the hoot of an owl in the dreams of a mouse
philth's Avatar
882
Drives: F87 N55, F15 N57
This has to be a troll post right?
No one in their right mind would just act like everything is fine and the bottom of the car just needs a clean…. Right?
Reminds me of a famous old troll post that exploded a mustang forum; long post short; guy said he wanted to clean his engine after buying the car so he attached his hose, drained the oil, turned on the tap and ran the engine with the water running. The forum exploded and was unreachable for hours after that.
FOUND THE POST!
https://mustangforums.com/forum/5-0l...-this-car.html
dcstep1723.50
      03-15-2026, 08:59 PM   #13
dcstep
FOUND THE POST!
He has thousands of posts here, BUT his Garage shows no NEW CARS.
Have to wonder how a troll makes it so far into a forum.
philth882.00
      03-15-2026, 11:08 PM   #14
learntocode
I wonder which brand new car this OP took his vehicle for its very first oil change.
Doubt it's a BMW Service Center. They don't allow anyone in the service bay or close enough to hear car underside pan drop on the ground... etc.
dcstep1723.50
      03-16-2026, 04:26 AM   #15
Emm2Upstart
Drives: G87 M2
Maybe this is a troll post or maybe OP got a little carried away with the story; maybe OP went to an indy shop, but my oil change experience at BMW Annapolis for my '26 M2 was shockingly similar with the mess they made.
      03-16-2026, 11:33 AM   #16
dcstep
Sorry to read that, BUT you didn't take it to an independent for its very first change and I'll bet that the dealer made it right.
I'll chime in with my own story: In 2009, on my very first change for my 2009 E92 M3 6MT, the dealer overfilled the engine. I noticed it on my drive home, made a U-turn and they fixed it quickly while I waited 15-minutes. I've never gone back to that dealer and still drive an hour each way to BMW of Loveland for exceptional service, 17-years later. There was no spillage in my case.
Give a dealer a 1 rating and they beg and grovel like crazy, but I didn't change my rating. For those in the Denver area, the guilty dealer's name starts with S.
Where's a dip stick when you need it?????
      03-16-2026, 11:52 AM   #17
dcstep
Now THAT was funny.
Makes our troll look like a brain surgeon.
philth882.00
      03-16-2026, 02:36 PM   #18
Phillies8008
Drives: BMWs, duh
2026 BMW Z4 M40i  [9.50]
2024 BMW i4 e40  [9.50]
2006 BMW Z4M  [10.00]
Now THAT was funny.
That was art. The second post is almost as funny – nothing says you really mean it like all caps and a huge font. Reminds me of old people who send emails in all caps, lol.
PLEASE CANCEL ME FROM THIS EMAIL ACCOUNT I DON'T KNOW HOW I GOT ON IT BUT I SHOULDN'T BE ON IT AND WILL CALL MY LAYWER IF I DON'T GET OFF IT THANK YOU VERY MUCH MILTON J HURLBUTT JR.
philth882.00
      03-17-2026, 03:47 AM   #19
spazzyfry123
Yeesh. Didn’t think this thread would turn this way. Been chasing three little ones through life, so haven’t been on here. Thought I’d ask the question in the general sense of advice to clean erratically drained oil from the bottom of a brand new vehicle. Didn’t think it would be considered a “troll post.” Vehicle has been parked since the incident and is scheduled to be cleaned today. Thanks all.
Efthreeoh22160.00
      03-17-2026, 08:29 AM   #20
Phillies8008
Drives: BMWs, duh
As much as anything in this world, people love to jump to conclusions.
Good luck with the cleaning – hope it works to your satisfaction.
      03-17-2026, 09:23 AM   #21
dcstep
He's still trolling. Don't take the bait.
      03-17-2026, 09:37 AM   #22
dcstep
Some pix might get you off the hook.
