2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F Series Coding/Programming issue, won't start now..
View Poll Results: What to do next
CAS ISSUE? 0 0%
DDE ISSUE? 0 0%
PROGRAMMING again? 0 0%
do replacement CAS and DDE in ISTA-P? 0 0%
after programming procedure error handling? 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
      03-20-2026, 05:46 AM   #1
JDAVID4208
Drives: F07
Exclamation F Series Coding/Programming issue, won't start now..
Hi there, did some updating on my F07 520d GT 2014, now won’t start..
- ISTA-P V3.67 2020 Version
- general update of all ECU’s (they all had old SW stands on it)
- all updated in green ✅ (besides HU/RAD and Kombi, cause programming without MOST, emulated ENET cable)
- went through all after programming procedures..
- no faults in any ECU
Issue:
- Key has to be on steering column to get ignition on
- engine cranks but won’t start
Observed:
- in CAS application the keys are enabled and it can be detected
- both keys have new key fob battery
- there’s no EWS synch anymore, cause of fixed ISN numbers in CAS and DDE
- showroom mode deactivated
I haven’t changed any ECU, just an update of all and now it won’t fire up.
Any ideas?
