Can Tire Dressings Cause the Browning of Tires?
Thread Tools |
| 04-12-2026, 11:01 PM | #1 |
Rep 1,233
Is it possible that tire dressings accelerate the browning color of tires?
My tires are only 10 months old, and I notice the sidewalls are aren’t jet black like they were when new. I only noticed this recently when I started using a “wet” tire dressing. Is there a correlation? I know all tires will eventually get some brown color due to UV exposure, but could the tire dressing possibly be accelerating the browning effect? It just seems more than I expect for 10 month old tires. |
| 04-12-2026, 11:41 PM | #2 |
![]() 207
Rep 173
Tire dressing will definitely make the tires brown. You need to periodically clean off the old dressing with a pretty strong wheel and tire cleaner and a stiff bristle brush. I've found that high pH cleaners are effective at this, though it may require multiple cleanings. Hit it with the cleaner, scrub, and rinse, until the foaming from the cleaner is white. When the cleaner is no longer turning brown, there's nothing left to remove.
Using a narrow nozzle (15º) from the pressure washer at close range can help speed this along, but tread carefully around the lips of the wheels. |
M5Rick90452.00 |
| 04-13-2026, 12:11 AM | #3 |
Rep 1,233
Fiveightandten, so is the browning merely superficial and due to the old dressing on the surface, or is the rubber permanently brown? I’m just trying to figure out if I use some real elbow grease, can I get my tires get back to their original jet black color?
| 04-13-2026, 02:18 PM | #4 |
![]() 2537
Rep 4,450
Drives: BMW G80 M3
I'm not sure if there's a causation between using tire dressing and browning, but there are products specifically for cleaning tires.
I use Gyeon Tire Cleaner and their tire brush every couple washes: https://gyeonusa.com/products/q-m-tirecleaner Then I put on their Tire Express dressing which gives more of a deep black factory look than a cheap shiny finish. My tires look brand new after 1.5 years. Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue
Past: 2021 Z4 M40i | 2017 340i Sedan 6MT | 2011 335i Coupe 6MT |
| 04-13-2026, 03:03 PM | #5 |
Rep 533
Drives: 2025 M340i XDrive
It’s not the dressing itself but a chemical process called tire blooming, and certain tire dressings can accelerate it or make the browning more visible.
What is tire blooming? It’s a natural process in modern tires where antiozonants migrate to the surface and oxidize. This is intentional, it protects the rubber from cracking and UV/ozone damage. The brown layer you see is simply those chemicals reacting with oxygen. Tire dressing can make this worse, especially solvent‑based or petroleum‑based products such as ExoForma Wet Tire Dressing, Armor All Tire Shine, and Chemical Guys Tire Shine Spray or their Nice & Wet Aerosol. These formulas can trap antiozonants at the surface or leave residue that oxidizes brown. What you want instead is a water‑based, polymer‑based, or resin‑based dressing, such as P&S Dressed Tire Finish, Adam’s Graphene VRT, or P&S Shine All. These don’t accelerate blooming and give a clean, deep black finish. The biggest tip is to keep your tires properly cleaned. You don’t need a stiff brush, just a quality tire/wheel cleaner that breaks down dirt, oils, and road grime so the dressing bonds cleanly instead of sitting on top of contamination. |
chris7197788.00 |
| 04-13-2026, 03:16 PM | #6 | |
![]() 207
Rep 173
This Ammo video explains it well. https://youtube.com/shorts/dUVrG_VXJ...LDMPoFJ4rASckq |
| 04-13-2026, 04:22 PM | #7 |
![]() 5836
Rep 4,477
Every couple of months, your tires need a "reset" with deep cleaning products to strip tire dressing off and get rid of the blooming. Products like Stoner Tarminator, mineral spirits, or even a degreaser will be required to pull it all out (every tire brand is a little different and will require varying levels of strength). Use a water based tire shine to minimize the blooming.
| 04-14-2026, 04:04 PM | #8 |
reads things
2881
Rep 4,065
Drives: DD - '24 840-x drive coupe
In the early ‘90’s Armorall turned everybody’s tires (and my Mx-6’s body molding) brown, and there was no bringing them back to black.
Hopefully yours just needs a good cleaning with a reputable produc, a brush and some new dressing but not armorall ![]() I don’t like ultra shiny tires, but I want them to have a nice black sheen. I’ve been using Meguiar’s Endurance for years about every 6 weeks in between and have no issues. My tires always look the way I like them, clean and black. Last edited by wrickem; 04-14-2026 at 04:10 PM.. |
| 04-14-2026, 05:12 PM | #9 |
Rep 1,233
Thanks everyone. This is all helpful. I thought if it was sold as a tire dressing, it would be safe. But apparently all tire dressings aren’t created equal. They should almost have a disclaimer warning that it may turn your tires brown. In the future, I think I’lol stay away from using them.
I used this stuff, by the way… is this solvent based or water based? I don’t know. ![]() |
| 04-14-2026, 07:37 PM | #10 |
Primo Generalissimo
5554
Rep 4,489
Drives: All of them
Garage List 2025 Corvette Z06 [10.00]
2024 Ford Bronco Ra ... [10.00] 2018 Porsche 911 GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I don’t use tire shine any more because of this plus all the sling regardless how careful you are. My tires look great just being washed nicely.
| 04-15-2026, 03:31 PM | #11 | |
![]() 2537
Rep 4,450
Drives: BMW G80 M3
Gyeon's Tire Express I mentioned (https://gyeonusa.com/products/q-m-ti...44405722972359) is water based and will not harm or discolor tires. It gives you a deeper contrast with a nice matte finish. Much better than dry rubber, IMO. As noted, the tires must be cleaned and stripped of whatever's on them before applying any kind of dressing/coating or you'll be creating problems. I use Gyeon Tire Cleaner with their brush, then apply Tire Express with a throwaway microfiber. (Gyeon sells little foam applicators for a couple dollars if you want to be ultra precise.) Charles
| Bookmarks |
