2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2015 F10 528ix Transfer Case Oil Error 440102: VTG Calibration/Oil wear
      05-03-2026, 11:21 AM   #1
ort11
Drives: bmw 2015 F10
195k
Just changed the fluid in the TC with TRIAX DTF-1. Rand the calibration using PROTOOL, Power On Engine Off. It said calibration complete with a value of 9.6xxxx. But the error keeps coming back.
1) Is this number an "ok" number of the calibration value?
2) Anything else needs to be done.
3) No other TC errors and car seems to drive fine.
      05-03-2026, 11:25 AM   #2
ort11
Well this is what google says
Context for ProTool Results
What is happening:
The calibration adjusts the actuator motor to determine the new zero point for the clutch pack, particularly after a fluid change, to eliminate "stutter" or "judder".
High Numbers: If the number is significantly higher than 1.5 (e.g., above 10 after calibration), it may indicate excessive wear within the transfer case, indicating the clutches are very worn or that the fluid was severely degraded.
Calibration Failure: If ProTool cannot complete the calibration or keeps returning high numbers, the VTG actuator gear may be damaged, or the fluid might need to be replaced again (a "flush").
      05-03-2026, 11:26 AM   #3
ort11
I will run this a bit and then transfer the fluid again and see hot it goes
