New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      03-13-2009, 03:23 PM   #1
maniac
Drives: 320d se '06
DCT vs. manual
In Holland the DCT transmission is offered for 1800 euros which is quit cheap, because BMW mostly offers the automatic transmissions for around 3500 euros. The DCT transmission looks like an obvious choice, with it's faster acceleration times and lower fuel comsumption. But is it really? Isn't it too much of perfection and wouldn't the manual be more fun? The only difference you will see with the acceleration time is when you will line up for a traffic light and then you are still faster than 99% of the cars (in Holland the average engine size is a 1.6 I think.) And who cares about the fuel comsuption when you are buying a twin turbo 6-cilinder?
So what do you guys think/prefer?
      03-13-2009, 03:42 PM   #2
Rubber Ducky
Rubber Ducky's Avatar
47
Drives: 2020 M340i
Key question: how rugged is it? To rephrase: will it take the added torque of a tuned engine?
The steptronic now in use is pretty bombproof and handles 420 lb-ft from a tuned N54 with Dinan firmware. Will the E89 DCT?
My buying decision hinges on this. Yes: buy E89. No: buy Corvette.
Anyone have info?
      03-14-2009, 03:54 AM   #3
JJ_Wonderboy
JJ_Wonderboy's Avatar
11
Drives: 2009 Z4 35i
Isn't the DCT basically a cutdown version of the one found in the M3? If so then it should be able to handle the extra torque. Bear in mind that the 335 also has a DCT option (probably very similar, or the same, as the one found in the new Z4) so I'd be interested to see if anyone has experience with tuning a DCT-based 335.
      03-14-2009, 04:46 AM   #4
TomT
Belgium
Drives: Z4 sDrive30iA
In my opinion it depends for what purpose you buy the car.
If it's a daily ride -> DCT
If it's a weekend ride -> DCT or manual
If you like to use the clutch while shifting, or if you're a fan of heel-toe while shifting down, than I would say: buy a manual. If not: DCT
      03-15-2009, 06:08 PM   #5
Rubber Ducky
47
Drives: 2020 M340i
M3 = 295 ft-lbs torque. N54 engine = 300 ft-lbs. N54 engine with Dinan firmware = ~420 ft-lbs.
M3 is not a good analog for the torque environment in a tuned 1-/3-/5-series or new Z4 with N54.
      03-16-2009, 03:08 AM   #6
JJ_Wonderboy
11
Drives: 2009 Z4 35i
Good point. Should have checked the stats first. Still, I've been looking into this a bit and found the following on wikipedia:
"In January 2008 BMW introduced a double clutch transmission on their M3 model, manufactured by Getrag and dubbed M DCT (M Dual Clutch Transmission). The same transmission is to be used in the upcoming redesigned Z4 (the Sdrive35i version)[15].
For 2009 models, DCT is an option on the 335i. This is a $1600 option over the manual transmission. The transmission is said to be able to hold 500 NM of torque."
http://en.wikipedia.org/wiki/Twin-clutch_gearbox
      03-16-2009, 07:07 AM   #7
Rubber Ducky
47
Drives: 2020 M340i
Good find. That equals about 370 lb-ft. The Dinan firmware puts out a fair bit more than that, so maybe no Dinan firmware with the DCT in the Z4.
Tie-breaker would be Dinan keeping their matching-warranty ('same as BMW's') and specifying that it would apply to a broken DCT if excess torque were involved - can't see them doing that, though.
      03-22-2009, 10:31 AM   #8
zEdP
Ed
Netherlands
18
I'm also thinking of choosing the DCT option. For me the fun factor and comfort is important. I'm not into heel-toe; I have tried to learn it...
So any of you who own or have owned a car equipped with a double clutch system:
  • Would you buy it again?
  • Or manual is the way to go?
Thanks...
Ed
      03-28-2009, 07:03 AM   #9
yabbanoname
yabbanoname's Avatar
Belgium
Drives: Z4 sDrive35i
Thanks...
Ed
Buy the DCT, who needs the manual clutch ? (if it is good enough for a Veyron, why not for a Beamer (okay, the tranny in a Veyron costs about $300.000)
Here a famous movie about Colin McRae Left Foot brake lessons (see him use his clutch ? (I don't):
GrtZ
Yo!
      03-29-2009, 02:29 PM   #10
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
If i don't remember wrong, they only need to use clutch to get into R and 1st gear. Once it's in 1st gear, they don't need to clutch to go up or down shift.
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      03-29-2009, 03:27 PM   #11
TomT
Belgium
Jep, that's correct.
The reason why i would buy a manual gearbox:
zpost
