European vs. US suspension setup - e90 325i
08-18-2006, 02:02 AM | #1 |
Rep 57
Ok guys, I searched but could not find any good info. I have European spec’d e 90 325i. Many people mentioned that there are some differences in the suspension setup between the European and US spec’d 325. Does any one know what the differences are?
08-18-2006, 03:59 AM | #2 | |
Rep 9,218
Wth sports suspension the limiter is set to 155mph, which implies it is at least as good as european standard. I doubt that the US sports set up is as firm as the m-sport. |
08-18-2006, 05:16 AM | #3 |
Orthopaedic Surgeon
Rep 93
Drives: BMW E90 320i
Consider this: European 325i has a 6L, 2.5L engine while US has a 6L, 3.0L engine. Different weight, different suspension setup.
08-18-2006, 05:26 AM | #4 | |
Rep 9,218
08-18-2006, 06:04 AM | #6 | |
Rep 19,368
08-18-2006, 06:20 AM | #7 |
Rep 57
checked the part numbers (on www.realoem.com) for springs, structs, coils and suspension bars for front and rear axles. Part numbers are the same for US and European models!! I am not sure if same part number is used for different specification parts for US and Europe models?!
Speed limit I think has to do with software setting and not car components, but could be wrong. |
08-18-2006, 06:32 AM | #8 | |
Rep 9,218
Looks like my theory might be wrong, but why set the limiter differently on sport / non sport in the US, but not europe? Also .... why does real OEM list 'sporty' and 'm-sport' - aren't there 3 suspension set ups: Normal Sports Msport Can you actually order msport suspension in the US? Confused ... |
08-18-2006, 06:38 AM | #9 |
Rep 6,750
Speed limiter has to do with the tires rating, safety and our more sue-happy Nation.
08-18-2006, 06:53 AM | #10 |
Orthopaedic Surgeon
Rep 93
Until now I believed that BMW sets the speed limiter according to German laws (250 Km/h speed limit - autobank). The same think applies to other german car manufacturers (Audi, VW, Mercedes-Banz etc). Anyone knows something different? As far as the car's weight, european and US 325i weighs about the same (1490kgs Europe vs 3285lbs US, 1kg~2.2lbs).
08-18-2006, 08:05 AM | #11 | |
Rep 29,202
08-18-2006, 08:34 AM | #12 | |
Rep 9,218
330i is also limited to the same speed(s). 325i in the UK will do 152mph and the 330i is limited to 155mph. Tyre size can't be the issue - so it can only be a legal or speed rating issue. UK tyres are effectively all season - we don't have summer / winter tyres cause the weather is usually crap. Speed ratings are usualy Y or Z - which is up to a constant 186mph or 150+ (mph) for 10 minutes respectively. Are the US tyres of a lower speed rating? V or H maybe? I still have a suspicion that the US suspension is softer. |
08-18-2006, 08:47 AM | #13 |
Rep 9,218
Just had another look on real OEM and there do appear to be some differences.
The front spring assembly is the same in the EU / US and both have 'msport' and 'sporty' But EU cars have 'sporty' and 'msport', stabiliser bars, spring struts, shock absorbers - US cars just have sporty. The sporty suspension seems to be the same in both countries. But the msport package seems more extensive in the EU (just springs in the US). Doesn't explain the speed limiter thing though. I think it's fair though cause you pay so much less for your cars |
08-18-2006, 10:32 AM | #14 | |
Rep 27,441
08-18-2006, 10:58 AM | #16 | |
Rep 9,218
08-18-2006, 11:21 AM | #18 | |
Rep 29,202
08-18-2006, 11:53 AM | #19 | |
Rep 57
Still I can not tell for sure if the standard US suspension is different from the european standard suspension. |
08-21-2006, 06:17 AM | #20 | |
Rep 9,218
But .... it looks like they are upgraded with sports suspension in the EU, but that only the springs are upgraded in the US. Sounds plausible .... would still like a definitive answer though. |
