335i not heating up!
12-24-2006, 09:17 PM | #1 |
Rep 159
what are you guys experiencing in terms of the engine temp gauge
it takes my car more than ten kilometers before the needle will move past the 70 degree celcius mark, then it usually stays at 110 degrees ...............range 70-170 deg C i have a 25 km commute to my workplace, and im almost half there before the temp gauge moves my old e46 will have the needle by the half way mark of the gauge after a few blocks anyone know whats going on? Last edited by DowntownBMW; 12-26-2006 at 05:38 PM.. |
12-24-2006, 09:19 PM | #2 |
Rep 4,172
Same thing with mine, I don't think it's abnormal. Car's don't need to "warm up" like they use to. Turn it on, wait for the revs to settle, and take off. The heater warms up long before the oil temp. Remember, your seeing oil temp, so it'll be slower than the actual engine temp.
12-26-2006, 03:15 PM | #4 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
My 325i E92 (UK) is exactly the same. At first I thought the gauge was broken
E89 Z4 sDrive 23i... for the more discerning driver
12-26-2006, 04:10 PM | #5 | |
Rep 4,172
12-26-2006, 04:16 PM | #6 |
Rep 134
Correct, it's the oil temp. There is not a water temp gauge (the gauge you're used to) on these cars. Oil takes much longer to heat up than water, also and may never show "warm" like you're used to with the old water temp gauge. In my A6, the oil temp would barely register heat unless I was cruising on the interstate.
12-26-2006, 05:38 PM | #7 |
Rep 159
ok boys, thanks
now that makes more sense! i didnt know it was water temp gauge i was looking at in my old e46, as i mentioned, it warms up quickly after a a few blocks! |
12-26-2006, 05:56 PM | #8 |
Rep 2,353
yes, on the z4 its a water temp gauge as well and rises fairly quickly.
12-27-2006, 11:30 AM | #9 |
Rep 11,668
FWIW...
The Z4M is oil temp as well. Very slow moving. Z4M also have LED warm up indicators on the tach. IIRC they're base on an algorithm of outside air, water & oil temp.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
