11-01-2010, 11:28 AM | #1 |
Rep 134
Variable Damper Control
I have only a few days left to change the spec on my order if I want delivery for Jan '11. The only thing I'm not sure about now is the VDC. I haven't ordered it and baulk at the idea of spending €1,500 on it. How important is it to the ride of the car? I will be getting 18' (328) rims and I drive on some of Ireland's worst roads - and they don't come much worse than here!
11-01-2010, 11:43 AM | #2 |
Rep 2,003
It depends if the VDC actualy works as intended. Although I have not tested it, I have suspicions whether the principle is sound, as dampers work in conjunction with springs, which are still static, so when you use VDC its only changing one part of a 2 part system, and the result can sometimes be even worse with no VDC.
Some here who have tested the full Adaptive drive (dampers+ARBs) here have commented that the dampers on soft setting makes one carsick, that the program may not be well matched. It may be different on just VDC however. Personally I prefer an only Active ARBs option (none exists), i have doubts on VDC. To be safe, you should at least try it first. |
11-01-2010, 12:03 PM | #3 |
Rep 1,008
I will strongly recommend it. If I where to buy only one extra on my car that would be it. It thigthens up your steering and gearbox too in sportmode. It transforms the car after the mood your in :-)
11-01-2010, 12:28 PM | #4 | |
Rep 3,016
As far as I'm aware, it comes as part of the Adaptive Drive package which comprises adjustable roll bars and VDC. It's £2,220 in the UK, so if you're being offered it for 1,500 Euros, I'd bite the dealers hand off! Either way, I'd recommend the system as you have the best of all worlds from soft to firm; however, I would personally prefer the 'sport' mode to be stiffer. Hunt around for a dealer who has a demo car with this option fitted and see for yourself. |
11-01-2010, 12:46 PM | #5 | |
Rep 70
On lower powered models you only get VDC, which is £950 in the U.K. |
11-01-2010, 12:54 PM | #6 | |
Rep 70
In my F11, I switch between the "comfort" setting on the motorway and "normal" for city driving at the touch of a button. Road imperfections are dealt with very well, and it's a huge difference compared to the standard suspension. The best thing you can do is try the standard suspension on 18" wheels for yourself to see if you're O.K with it. |
11-01-2010, 01:09 PM | #7 | |
Rep 3,016
I would think that VDC alone should make a noticeable difference as to how the car feels on rough surfaces, but I cannot speak from experience. So, to reiterate my earlier suggestion, I would recommend that the OP should test the VDC if possible. |
11-09-2010, 02:36 PM | #8 |
Rep 12
Very happy with the VDC on my 520dA. Gives best of both worlds, even in Sport and Sport+ mode it is still extremely comfortable. And I compared with non-VDC cars before ordering.
11-09-2010, 05:28 PM | #9 |
Winker
Rep 36
If there is one option to get it is VDC. Comfort mode is superb on motorways and makes the ride exceptionally smooth even on other roads. It is also an economic way of driving. The car comes alive in sport mode on roads with plenty of bends
11-10-2010, 03:43 AM | #10 |
Rep 229
I just got my car two days ago and it has VDC. Haven't tested the VDC very much yet but I am starting to think that I should have ordered the M sport suspension instead. The Comfort mode is very soft and even the sport mode is quite soft. If it wasn't a leased car I think I would have gone with M sport suspension and lowered springs. Maybe I feel differently one I have tested the VDC some more.
11-10-2010, 03:48 AM | #11 | |
Rep 229
11-10-2010, 04:53 AM | #12 |
Rep 2,064
I think the VDC is only relevant as part of adaptive drive. Because selecting a mode in adaptive drive will not only set the dampers but matching throttle respons and gearchange characteristics as well. Plus you get the next gen. suspension technology (dynamic drive) which makes a fundamental difference.
I also agree that damper settings within sport mode is still quite soft compared to traditional M sport suspensions (like in a e92 for example). That's why I changed the springset. To my own surprise I have used the comfort mode a lot, specially in heavy rush hour highway traffic. I mean what's the point of a super stiff and sporty ride when there's no room to manoeuvre in the first place? I cannot see the point of VDC as standalone option though: go for the M suspension instead.
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
11-10-2010, 05:22 AM | #13 | |
Rep 70
11-10-2010, 06:49 AM | #14 | |
Rep 15,858
As I see it, it is just to fine tune the standard supension 'to taste'. As we have discussed before, even the full package of Adaptive Drive will never be like the M-sport setup, it is too different in concept. The passive M-sport suspension is the only setup that will feel firm, in the way we are used to sport suspensions. Albeit softer than some BMW M-sport models. HighlandPete |
11-10-2010, 06:57 AM | #15 | |
Rep 15,858
HighlandPete |
11-10-2010, 07:04 AM | #16 |
Rep 1,128
Does it do that with standard steering or just the Integral Active Steering?
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3 Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del |
11-10-2010, 10:11 AM | #17 | |
Rep 2,003
The other part of Adaptive drive, the variable antiroll bars, performs a different function, which is to manage the transfer of weight via suspension compression between the two sides of the car in turns. If you are driving straight, ARBs variable or not, do not perform any postive function, which is why you want no ARBs if you never had to turn; hitting a pothole/road imperfection would tranfer minor jiggles to the other side of the suspension, which is not prefered to having it isolated and dealt with the suspension only on one side. VDC=ability to deal with bad roads variable ARB= soft in straight, hard on turns =no body roll any of VDC/sportauto/IAS/Adaptive gives the Dynamic drive function for transmission+steering variability control |
11-10-2010, 10:36 AM | #18 | |
Rep 70
It doesn't bother me either way. I bought VDC primarily to deal with bad roads better than the standard suspension did. I'll get immediate disapproving comments from my wife and kids if I throw the car around |
11-10-2010, 10:57 AM | #19 | |
Rep 2,064
I checked the BMW tech guide and VDC is indeed an active system, even if it is not part of Adaptive drive. VDC not only gives you a few damper preset modes but also is an active system: " A control unit on each wheel evaluates movements four hundred times a second and adjusts the shock absorbers accordingly. The electronics system works so fast that when the front wheels encounter a pothole, information is sent to the rear wheels so that sufficient cushioning is in place. The rebound and compression damping are continually and independently set." So, I have to correct myself: VDC seems worthwhile as a separate option as well. Do you know if the throttle/gearchanging characteristics also change when selecting a different VDC mode?
11-10-2010, 11:02 AM | #20 |
Rep 229
11-10-2010, 11:05 AM | #21 | |
Rep 2,003
i stopped throwing my car around once some small squeeks started appearing, but fortunately they go away once you go back to 'normal' -the squeeks are 'variable' too |
11-10-2010, 11:22 AM | #22 | |
Rep 2,003
Yeah, I find that part about active VDC ambiguous, it does not mention how or what it is actively doing. Do you think it really does soften up the back damper when the front damper hits a pothole? If so, that would be amazing .. you can calculate the amount of time this would have to be accomplished in, the valve mechanism would have to be electronic to react that fast. Also, it can also adjust for each side of the road independently, if you are driving on the median/rough on one side, it will soften that side and keep the other side harder! That is truly a big promise. And also why I have questions on how it works/how well it works in real life, because it hits up against the limits of damper techonology (which I know nothing about, so I'm doing a lot of guesswork here). It is complicated, and that some reviews have been mixed, there are alot of unknowns to us endusers still. (I suppose you can adjust for transmission and/or steering on 'sport', just like on other VDC enabled cars. On the change from comfort to normal, I don't know but I would guess it stays the same, only the damper/ARB part would change.) |
