2010 2011 BMW 5 Series Forum F10 Valentine 1 Continuous K Band False Alarm |
11-14-2010, 06:23 PM | #1 |
Rep 42
Installed my Valentine 1 in my 2011 535I and was greeted by continuous K band false alarms with arrow pointing to the rear. Does anyone have any idea on what might be causing this? I tried shutting off the lane departure and blind area indicator sensors but it had no effect.
11-16-2010, 05:55 AM | #3 |
Rep 15
02-01-2011, 07:53 AM | #5 |
Rep 111
Still configuring what I'll order and am concerned about this issue. Spoke to Valentine about the problem.
I'm told that lane departure and blind area indicator sensors are always on (just the notification is turned off), they are K band and will activate the Valentine. They thought to deactivate POP on the Valentine would solve the problem. I won't get the lane departure and blind area indicator if it's degrades the Valentine's performance. What have others discovered?? Your experience? Thanks. |
02-01-2011, 09:08 AM | #6 | |
Rep 24
02-03-2011, 02:17 PM | #10 |
Rep 10
Try disabling POP - worked for me
Try disabling POP on your V1 - worked for me:
http://www.valentine1.com/Lab/techreport3.asp Also, see this article: http://veilguy.blogspot.com/2007/04/...ntine-one.html Cheers, zgco |
02-03-2011, 03:53 PM | #11 | |
Rep 111
and Lane Departure Warning...yes? And with POP disabled, the Valentine 1 seems to be working optimally? |
02-03-2011, 10:41 PM | #12 |
Rep 10
Yes and yes
Yes, I have active blind spot detection and lane departure and with POP disabled on the Valentine 1 it has been quite. Before disabling POP, the detector would false even in my driveway; it no longer does this. I have X band and POP disabled on the Valentine 1; all other settings are factory. It is worth a try as disabling pop only takes a minute to do - nothing lost if it does not work for you. Cheers.
02-04-2011, 08:44 AM | #13 |
Rep 1,730
Just sell it like I did lol.
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey) 11 F10 535i AW/CB Mods Gone |
04-07-2013, 08:00 PM | #15 |
Rep 62
You need to disable the k pop detection via the programming, check the v1 website, it is easy. The blind spot detection is what is causing it and the dash switch does not shut off the detection, just the buzz in the steering wheel. I have not had this problem since doing it and no issues with radars. Read up on what k pop is on the v1 site as well.
Best regards,
Don M |
