| 10-13-2011, 06:33 PM | #1 |
![]() 386
Rep 2,255
Swirl Mark Removal
Other than clear coating an entire panel, is there any way to permanently remove swirl mark holograms caused by a power buffer wheel?
The detailer at the dealership says glaze, but I've researched same and it seems to be temporary!? Last edited by dbs600; 10-13-2011 at 07:01 PM.. |
| 10-13-2011, 06:42 PM | #2 |
![]() 272
Rep 1,450
Drives: '23 i4 M50, '15 M3, '19 Cayman
A detailer with the appropriate power tools. It has to be buffed out.
Here a kit: PC 7424-XP Starter kit Or a higher quality tool starter kit: Flex 3401 Kit Add some polish and read up on the detailer's forums. I purchased a Flex, did some research, and ended up with great results. Or you can save yourself time and go to a professional. But good pros can be hard to find. |
| 10-13-2011, 07:03 PM | #3 |
![]() 386
Rep 2,255
Thank you for your informative reply!
Does anyone know of a very good detailer near the Five Towns (Hewlett, Woodmere, Cedarhurst, Lawrence, etc.) on Long Island? |
| 10-18-2011, 08:54 PM | #7 |
![]() 386
Rep 2,255
Passed by a body shop and turned around to see what they would recommend. Said they would wet sand the areas for $200. I'm not saying I'm going to necessarily go this route, but any comments on wet sanding to remove swirl marks? I believe wet sanding to remove 'fish eyes' is what caused this in the first place...
| 10-18-2011, 09:56 PM | #9 |
![]() 386
Rep 2,255
Thanks ceb; it's not that I don't want to take your advice; I do, which is why I've posted, but I was just passing a body shop and stopped in to ask, and so I was now wondering if wet sanding would do more harm than good.
| 10-18-2011, 11:40 PM | #10 |
![]() 386
Rep 2,255
Thanks all of the info, MERKSuk. Before setting up an account, I decided to e-mail the site administrator and ask for recommendations directly. I Haven't heard back, so I'll go forth and register. Otherwise, I'll also have to snap some pictures when the car is clean and in direct sunlight and post. Thanks again.
| 10-19-2011, 11:27 AM | #11 |
NHTSA Nazi
33
Rep 1,983
Understood but you need to remember to start with the least agressive method first. Wetsanding is not for swirl removal - assuming that your definition of swirl is the same as mine.
| 10-19-2011, 03:05 PM | #12 |
![]() 386
Rep 2,255
Got it!
And, just posted this: http://www.detailingbliss.com/forum/...rk-removal.htm Let's see if anyone bites... Last edited by dbs600; 10-19-2011 at 07:45 PM.. |
| 10-20-2011, 12:30 PM | #13 |
![]() 386
Rep 2,255
Here are some pictures of the marks. It actually looks worse in person when walking up to the car from a distance. How severe would this be considered?
| 10-20-2011, 12:42 PM | #14 |
Rep 379
If you're the DIY type buy or rent a dual-action polisher and some proper polish - e.g. Meguiar's ultra compound and the less aggressive stuff. You have to educate yourself about polishes, proper way to handle a polisher, paint thickness,etc. It's not that hard to polish your car, but you have to know the basics. If too much hassle - take it to a professional detailer. As a side note - you can't do this too often - polishing effectively removes part of the car paint's clearcoat. After you get an 'as new' look be careful how you wash it - there are plenty of good tutorials - look up two buckets method, never go to automated car washes etc. You won't completely eliminate swirls but you can minimise them.
Check this out: http://www.polishedbliss.co.uk/acata...re-advice.html Last edited by Breach; 10-20-2011 at 12:50 PM.. |
| 10-20-2011, 01:54 PM | #15 |
![]() ![]() ![]() ![]() 98
Rep 937
From the pictures, I would say whoever told you that you need to wetsand doesn't know much about paint.
Your car's paint just needs to be polished. As others have recommended, get an orbital polisher and educate yourself, or find a good detailer. |
| 10-23-2011, 11:47 AM | #16 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
Wetsanding to remove swirls?
![]() You just need someone to clay, polish and wax the car, that's it. Those swirls don't look like buffer marks to me, they look like typical marring from improper washing. My New Car Prep Process: BMW 550
| 10-23-2011, 03:08 PM | #17 | |
![]() 386
Rep 2,255
| 10-23-2011, 04:16 PM | #18 |
![]() ![]() ![]() 11850
Rep 11,219
Looking at your pictures, a wetsand is not required. Looks like some improper rotary work, which is actually quite common. These can be removed with a Porter Cable 7424XP or a Flex XC 3401, which are both DA units (the Flex being forced DA).
If you enjoy taking care of your vehicle, this can be easily performed at home by yourself. Detailers Domain sells some nice kits. I personally would recommend starting with the green Uber pad and Menzerna Super Finish. It's probably the best "one step" correction out there. Let me know if you have any further questions, I'm a mod on Detailing Bliss also. |
| 10-23-2011, 07:55 PM | #19 |
NHTSA Nazi
33
Rep 1,983
Anybody who suggested wetsanding is a complete dolt and just validates my point that ealers and bodyshops are clueless about paint care.
It is very simple Wash, clay, polish and wax. If you don't want to do it yourself then get a good detailer to do it but do not let anybody wetsand that. |
| Bookmarks |
