2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions ACC/IGN Wire in engine bay- Where?
      11-22-2012, 06:08 PM   #1
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Hey there-
I would like to know where I can find one please. Or which is the power wire for the factory angel eyes?
Installing some additional aux lighting today and I know I will need power & ground, but power only from ACC/IGN/angel eyes if I can find the leads.
Also, is it safe to tap into the angel eyes positive/power wire to power another set of led lighting? The power wire to the other set of lights will be fused. Should be ok right?
Thanks guys.
      11-25-2012, 10:43 PM   #2
Aaron@Autosource
98
Drives: F110/F22
Anyone??
      12-22-2012, 06:33 PM   #3
Tdubyu
Tdubyu's Avatar
Drives: 2012 535i
2012 535I  [0.00]
2012 BMW/535i  [0.00]
Originally Posted by lll F10 lll View Post
Hey there-
Thanks guys.
Did you ever get an answer on this request or did you take a chance and located the connection yourself. If so, where did you hook them to?
Thanks
      01-08-2013, 02:42 AM   #4
Aaron@Autosource
98
Drives: F110/F22
I did! I just dug around and found the right ones. I wired my auxiliary lighting to a pair of wires inside the headlight "compartment" after you lift the lid of the headlamp area, it is a green and brown(or black) wire set.
      10-07-2013, 05:34 PM   #5
shikbas
Drives: Bimmer
Can you please tell that you tapped the positve and negative on this set? Thank u
