2010 2011 BMW 5 Series Forum F10 Rear Left wheels pokes more than the right wheels |
10-06-2013, 09:44 AM | #1 |
Rep 194
Drives: G35 - E92 335i AW/CR - F10 BSM
I have recently put on 20" adv with aggressive offset and install BC coilover at the same time. For some reason, rear left wheels pokes out more than the rear right, may be 2-3mm more if I have to guess. Is this strictly alignment issue or I have mismatched offset? Thanks.
10-06-2013, 11:06 AM | #2 | |
Rep 217
Drives: shifting priorities for now...
10-06-2013, 07:45 PM | #3 |
Rep 194
This is the left side, passanger side in Indonesia
This is the right side (driver) with 3/4 tank. Last edited by mubay; 10-06-2013 at 07:51 PM.. |
10-06-2013, 09:43 PM | #4 |
Rep 217
I'm located in Jakarta too LOL
10-06-2013, 10:26 PM | #5 |
Rep 194
10-06-2013, 11:37 PM | #6 |
Rep 217
Looks like it. At least to me. Try this, unmounts the wheel in question, look at the back of the wheel, you should see a writing "ET", and compare it to the other side
10-07-2013, 10:06 AM | #7 |
Rep 8,279
I highly doubt the wheels have different offsets then each other. Being that you're on coils make sure they are evenly lowered.
I know from experience that the right rear sits lower then the left which will make the wheel camber in more. Tip, You might want to lower your rear right a bit more or raise your rear left a bit to compensate. |
10-07-2013, 11:48 PM | #8 | |
Rep 194
10-09-2013, 09:14 PM | #9 |
Rep 217
What LACSTER meant to say is that try lowering the side which your wheel is poking out
10-10-2013, 02:49 AM | #10 |
Rep 55
As I was told by BMW representative, that is normal (rear axle off center), I have oem mpeformace wheels on my f11 (self leveling air suspension on the rear axle) and my rear right wheel is tucked in 3mm more than left one, same as in your case.
10-22-2013, 09:21 PM | #11 |
Rep 194
I just got an alignment to run more camber on the back, around -2.20 and that side is still rubbing. Do you guys think running stretched tires would resolve the problem? I'm afraid that the wheels poke too much where the lip would hit the fender anyway (with stretched tires) if I ran into big dip on high speed. The highway pavement in Indonesia is really bumpy.
