2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire Pressures for 20" tires
      03-15-2014, 07:54 PM   #1
weissja
Drives: 2014 BMW 550i
Any suggestions on the tire pressures for this set up: 20" BMW 464M wheels with 245/35 R20 (front) / 275/30 R20 (rear). These are on a 2014 550i.
Original tires were 19" 351M set up with 245/40/19 (front) and 27535/19 (rear) with recommended tire pressures of 36 front, 38 rear.
      03-15-2014, 08:10 PM   #2
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
Those pressures would work with 20" too. I ran 38 all around on my 20" setup and it rode good
      03-16-2014, 10:27 PM   #3
CaliE90
CaliE90's Avatar
365
2021 M550xi  [0.00]
Good rule of thumb is to follow the recommended fill pressure for 20 inch wheels in the owner's manual. believe it or not the manual actually gives you various recommendation based on wheel size.
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
      03-18-2014, 01:13 PM   #4
VMRWheels
VMRWheels's Avatar
2070
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I usually recommend checking the door jamb or the owners manual for the proper pressure recommendations. Then you can adjust them up or down according to your driving style and preferences.
      03-26-2014, 08:57 AM   #5
Holygrail
Holygrail's Avatar
Drives: 2008 BMW E90 335i
2008 335i Sedan  [0.00]
Once you plus size it, you can't really go by the door jam numbers. The numbers are for the OEM 19" wheels, if you have the M-pkg that is. I'm about to add new 20" wheels and tires this weekend. I'll be running Continental Extreme Contact DWSs 245/35ZR20 (20x9) and 285/30ZR20 (20x10), and I would inflate at least to 38psi front and 40psi back at cold temperature.
      03-26-2014, 08:59 AM   #6
Holygrail
Holygrail's Avatar
Forgot to mention, the added pressure during plus sizing is to compensate for less side walls and pot holes/bumps.
      03-26-2014, 08:40 PM   #7
weissja
Thanks. Makes sense.
