2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Anyone successfully coded F10 in the UK?
      09-21-2017, 03:18 PM   #485
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
So it is not possible to code LDW , i thought that you maneged to code it reading the first pages of this treath ? thank you because you are the first that givves me a straith answer on this. Others say it is possible to code it without the vibraiton motor in the steeringwheel others say it is possible but you get error messages and some say they coded it on there cars without problem. so did not knowh what to believe
Thank you i will stop searching for more readings on this subject.
My car is from 2016 but i dont have the options here below on my HBT navi pro.
- Route Magnet (What is Route Magnet ?)
- Route Simulation : I understand this you have this on a Garmin,TomTom
- Avoid Route ( not taking that route i think )
- Auto Zoom SatNav maps ( I dont think i have that eather )
Can i code these things ?
Thank you Gspannu
      09-21-2017, 07:18 PM   #486
gspannu
Drives: F10 535, F82 M4
Thank you Gspannu
I wouldn’t categorically state that it can’t be coded, and as you have written some forum members are stating that they were able to make it work.
I tried but couldn’t get through; and eventually it dawned on me that without the steering vibration motor, the effort wasn’t worth it.
Other options you have mentioned can be coded.
Route Magnet: This allows you to force navigation via a particular road, almost like a waypoint without having to set separate destinations. Useful in certain situations where you want to reach your destination but go via certain road and the satnav does not route via that road.
Avoid Route: The opposite of the above. Don’t go through a certain area. Useful if you know there are permanent roadworks or closures in an area, but the satnav routes it via that road/ area.
Route simulation: Provides an overview of the route but in an animated fashion. You can choose the speed of playback so it gives an idea of the overall complexity of the route. It’s a great gimmick to show off, not much real world use - I think.
Auto Zoom: Does not work on all cars. Depends what f/w version you have, but give it a try. It might work. Once coded, you need to select the zoom level as auto for this to work - that’s what I recall.
I haven’t coded my F10 for a while, so am forgetting a few things.
Enjoy !
      09-22-2017, 04:59 AM   #487
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
LDW
Hello Gspannu.
Thank you for the information , i will wait and see if LDW is possible to code in the future..
Do you now the codes for thesecdings ?
I dont find them in the cheats.
Thank you .
      09-22-2017, 05:08 AM   #488
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
Enjoy !
IIRC there was an Auto Zoom on my old CIC but it was a bit unconventional because it zoomed to show the whole route so, if you navigated from Aberdeen to Penzance, it would start by showing the whole country and slowly shrink to just showing Penzance by the time you got there. It was selected by zooming the map out as far as possible to Auto, but it was a complete waste of time unless you just want the Sat Nav as an ornament.
      09-22-2017, 06:00 AM   #489
gspannu
Hello Gspannu.
Thank you .
See attached... dug it from some old notes !
      09-23-2017, 04:40 AM   #490
JLR1969
Drives: Kubota GR1600
I am going to code my F10 2016 next week and wanted to ask can you code the door handle lights to illuminate when I select reverse?
Thanks
      09-23-2017, 05:35 AM   #491
gspannu
Thanks
Nope. Not available on the F1x series unfortunately.
      09-23-2017, 05:53 AM   #492
JLR1969
Do you have a cheat sheet for what is available please?
      09-24-2017, 02:03 AM   #493
SpeedTrip
SpeedTrip's Avatar
England
27
Drives: F21 M140i LCI-2 Alpine
Not sure how recent this is :-
https://docs.google.com/spreadsheets...Jo8/edit#gid=0
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2
JLR19691882.00
gspannu199.50
      09-24-2017, 01:24 PM   #494
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
Easy Entry Seat
Hello ..
Are there people who have code the
EASY ENTRY SEAT ? what thous it exactly means and how thous it works?
What do i have to code exactly ?
Thank you.
      09-24-2017, 05:33 PM   #495
gspannu
Hello ..
Thank you.
The module is SM[6d] for driver and SM[6e] for the passenger.
EINAUSSTIEGSHILFE > Modus_FA -> Modus_FA_SLV
GENTLEMAN > nicht_aktiv -> aktiv
EAH_VERFAHRWEG_SLV_PHYS > 00,3C (00,60mm) -> Set to what you like
Essentially, if you have full electric seats - this feature allows easy exit.
After driving to a stop, you shut down the car, you open the door; and the seats move backwards (value = 3C hex= 60mm) and allow for an easier exit.
      09-25-2017, 02:07 AM   #496
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
Thank you gspannu... This explains it better (these codings are all in the same module SM ?? I am going to givve this a try...
Thank you.
      09-25-2017, 04:37 AM   #497
gspannu
Thank you.
Yes. All in the same module. SM6x.
6D is for driver and 6E is for passenger.
      09-26-2017, 09:08 AM   #498
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
gspannu thank you coded the
and everything when fine , just had to play with the
Distance Values
mm Inches Hex
100 3.93701 00,64
90 3.543309 00,5A
80 3.149608 00,50
70 2.755907 00,46
60 2.362206 00,3C
50 1.968505 00,32
40 1.574804 00,28
30 1.181103 00,1E
20 0.787402 00,14
10 0.393701 00,0A
0 0 00,00
to find the right distance that the seat wil move backwards.
But did not find SM[6e] for the passenger in the SM module.
But thank you anywhyay.
      09-28-2017, 03:55 PM   #499
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
I heard that there are new PSDZData files 3.62.5 ? is this true ? Where can i find the link ?
Thank you
      09-29-2017, 02:48 AM   #500
gspannu
Distance Values
mm Inches Hex
100 3.93701 00,64
90 3.543309 00,5A
80 3.149608 00,50
70 2.755907 00,46
60 2.362206 00,3C
50 1.968505 00,32
40 1.574804 00,28
30 1.181103 00,1E
20 0.787402 00,14
10 0.393701 00,0A
0 0 00,00
You should definitely have 2 SM modules. Please check again...
      09-29-2017, 01:59 PM   #501
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
I will look again tomorrow , but i already looked twice and did not find the second SM modelu (6e)
Thank you
      09-29-2017, 02:34 PM   #502
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
gspannu here is my CAFD file i only find 1 SM module
Here is a link to my CAFD file
https://mega.nz/#!qVhEXDSI!I3wNj-0sP...1WanKgFISbtQXE
the key
!I3wNj-0sP8Knd0Jc0Lso1hFH7tt3N1WanKgFISbtQXE
      09-29-2017, 04:35 PM   #503
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
Rear view camera..
Hello..
I code my rear view camera to always on werte ff
And it works but if you drive faster then 30KM the camera will not com on anymore .. What did i do wrong?? T tought we activate the camera at all speeds ?
Thank you.
      10-01-2017, 11:58 AM   #504
JLR1969
I have the Bimmer code app with expert mode which has been very good and I have coded quite a lot that's actually useful.
However I cannot work out how to fold the wing mirrors when the car is locked.
It will fold them if I hold the key fob or the comfort access on the handle for a few seconds but want it to fold them on lock.
Can anyone advise?
Thanks
      10-01-2017, 12:31 PM   #505
silo24
Drives: F10 LCI 535d
Can anyone advise?
Thanks
Only way to do this is to change the delay time on the comfort close function.
Basically when you hold the lock button, it usually takes a couple of seconds to start folding, but the delay can be programmed. I have mine set to around 0.5 seconds.
F10 LCI 535d (313PS) M Sport
      10-01-2017, 01:01 PM   #506
JLR1969
Do you have the modules and steps etc?
