2010 2011 BMW 5 Series Forum F10 ANY DIY for installing Front Spoilers/ rear Diffusers? |
11-09-2016, 11:10 AM | #2 |
Rep 297
I have a CF 3D design rear diffuser and pending purchase of a CF front M performance Spoiler... Looking to do the installation myself if its easy...
11-09-2016, 12:09 PM | #3 |
Rep 544
I just posted pics of my carbon front and rear setup. They're very straight forward and while the front lip may take some modification and drilling, not difficult at all. If you have a higher quality setup they should fit better than most Ebay items.
Assuming you have an M-Sport For the rear, there are 3 or 4 screws underneath and a handful of "push pins" holding it on. Remove those and then pull gently towards you and out starting on one side of the bumper cover and then the other. It should just pop right out, only held on by simple tabs. Once it's off the carbon one goes on just as easy. The front will take more work depending on the fit but it should be straight forward as well. |
11-09-2016, 12:11 PM | #4 |
Rep 470
It is pretty easy, Ill look around for a DIY as I have seen a couple on the forums. I recently installed a vorsteiner lip and would recommend you get a second person to help. If you have some blocks to raise the front end up, that helps. You basically just need a few self tapping screws, as the front lip should have pre cut holes underneath which you simply screw up into the bumper. The "difficult" part is keeping the lip in place while you install the screws. I only had myself, so I wedged a stack of books up under the lip to keep it in place while I secured the screws. It came out a little lower than I wanted, but its on securely.
And I also just did a diffuser install, which is extremely easy. There is 4 or 5 pins on the underside which you simply pop out first. Once those are undone, the diffuser has clips all the way around the top and sides, but these pop right out with a soft pull. Work your way around starting on one side, and with a little pulling it will fall right off. I'd recommend having a towel underneath in case you drop the diffuser, although its very light so it's not likely you will
2016 535d M Sport, Space Gray/Mocha Past: '14 328, '08 335, '04 525, '91 M5, '95 525 Last edited by thebmwjunkiee; 11-09-2016 at 12:32 PM.. |
11-09-2016, 12:17 PM | #5 |
Rep 297
Thanks Guys, the front is OEM Performance lip, so fitment shouldn't be an issue. I'll play with that this weekend. I look forward to the DIY if you ever find it, BMWJunkie.
Thanks |
11-09-2016, 12:19 PM | #6 | |
Rep 297
So, I don't need to remove the bumper cover at all? nice |
11-09-2016, 12:21 PM | #7 |
Rep 544
http://f10.5post.com/forums/showthre...3#post20828763
No need to remove the bumper covers...either of them. |
11-09-2016, 12:23 PM | #8 |
Rep 470
No, its not necessary to remove the front bumper. Just try to park somewhere where you have enough room to get under and operate the drill straight. For now, heres the diffuser video I used
Diffuser install:
2016 535d M Sport, Space Gray/Mocha Past: '14 328, '08 335, '04 525, '91 M5, '95 525 |
11-09-2016, 12:40 PM | #10 | |
938
Rep 4,329
Drives: M340
Like others stated, it helps to have another person and elevate the front of the car. Also, you might consider using betalink. Please keep us posted.
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired Last edited by TTG; 11-09-2016 at 03:27 PM.. |
11-10-2016, 09:37 AM | #13 |
Rep 297
Thanks, I will. I am buying from another forum member locally. it comes with the 3mm tape. Will that be sufficient? The splitter/spoiler comes with 5 pre drilled hole. 2 on each splitter and one on the middle. Are they meant to be used with the same fasteners under the bumper cover?
11-14-2016, 03:23 PM | #14 |
Rep 345
Rear Diffuser
http://f10.5post.com/forums/showthread.php?t=887130 http://f10.5post.com/forums/showthread.php?t=950378
Current: 2013 F10
Previous: 2007 E90 Previous: 1994 E34 |
