05-29-2011, 02:37 AM | #2 |
BMW Noobie
63
Rep 360
I'm going to be installing them onto my car next week. 13mm in front 5mm or a 10mm in rear.
I've run them on all my previous cars when I wanted a better stance than what the wheels could provide. On my E320 and E55 I had no issues as I had 25mm rear and 8mm front on a previous setup. The great thing is we have lug bolts not lug nuts so there really is no downside in my opinion.
06-04-2011, 04:34 PM | #5 |
Rep 29,202
You mean why bigger spacer in the front? I assume it's because the front wheels sits in more than the rear wheels.
06-04-2011, 07:01 PM | #6 |
BMW Noobie
63
Rep 360
I had my spacers installed on Thursday and am quite satisfied with the fitment of my wheels now.
BBS LMR 20x8.5 +32 offset (front) and 20x9.5 +35 offset (rear) Spacers 13mm front and 5mm rear So the net value of my setup is +19 front and +30 rear I will take some photos of it next week to share with you guys. But at the moment I have the wheels flush to the body with no rubbing at all. I can take all turns, uturns, sweeping freeway dips at freeway speeds with no issues. Even with these spacers now i can easily go another 5mm in the front but that wouldnt be flush anymore and be poking >
06-13-2011, 01:00 PM | #9 |
BMW Noobie
63
Rep 360
On my car my offsets are 20x8.5 ET19 and 20.9.5 ET30
Using the http://www.1010tires.com/wheeloffsetcalculator.asp calculator it says your wheels compared to my setup is the following 14mm retracted (sunken in) on the front 20mm retracted (sunken in) on the rear If you lower your car as I have your wheels should be flush to the body with no rubbing at all. Otherwise on a stock body and not lowered your wheels will probably look like they are poking out a bit. I went out friday during lunch with 4 people in the car including myself and had no rubbing at all.
